Thread: Noticable power loss from cold (Glowplugs ?)
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Default Noticable power loss from cold (Glowplugs ?)
    Hey .
    Been a bit quiet as Ive been working on the missus a4 so been on other ( much poorer) Audi forums .
    jumped back in my veccy this morning and there was definately less power in the first 10 - 20 miles until the engine warmed then back to normal. I have noticed this before but since the car is now running very well with no hesitation flat spots etc it is more noticeable.
    I have done a search but cannot find the answer to these questions.
    At what temp will the pre and post heating occur and can glow plugs be rubbish without throwing up the eml light as other people have posted?
    The car starts ok not as soon as you touch the key but a couple of revs of the crank and it's away.
    Thanks people
    All the glowplugs do is help with the starting. Nothing else.
    Jan 2010
    Blackburn
    No post heating at all controlled by the ecu ?
    Oh well back to the thinking board
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    usually the glow plugs will always still be working after start up!, to check you could put at meter on them to check,
    Cambridgeshire
    Mine was running quite rough. Then I had an EML come on during start up and 3 glow plugs were out got them changed and it ran like a new car
    Regular Member TonyTM's Avatar
    Timisoara - Romania
    I have the same problem. The flat spot under 2000 rpm is present only until the engine reaches 75-80 C. After that the car drives better. If I take out the EGR the flat spot disappears. So I bet you have a tired EGR solenoid as well.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Noticable power loss with air-con on
    By Gmc12 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 16:15
  3. Noticable power loss when Air-con is on
    By Gmc12 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2011, 01:47
  4. 2.2 petrol - loss of power when cold
    By gokartin in forum Engine & Drivetrain
    Last Post: 10th September 2010, 18:24
  5. loss of power
    By dcdevlin in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 20:58
