Thread: OEM sat nav aerial
    In a house
    Default OEM sat nav aerial
    Ok guys, has anyone fitted an OEM aerial when upgrading their original headunit to the CD70 navi headunit, for any of you that have, how difficult or easy was it,
    Regards,
    Saxman.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Ive done it on my NCDC and its just the same very easy to do if you have the leads
    Irmscher Insignia CDTI 130
    In a house
    Quote Originally Posted by bigmac View Post
    Thanks, forgot to mention, mines an estate would that make the job any easier / more difficult, also whats the prodcedure for fitting the OEM aerial ?,
    Regards,
    Saxman.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Cant see it being any different.
    You need Navi Ariel base and navi aerial lead then lead from front connector block in front drivers side kick panel to radio,all i did was undo old aerial from roof you drop rear headlining and remove nut and disconnect aerial lead and remove,then replace with new Aerial and undo crab handles on drivers side to allow you to drop headlining.
    The new aerial will have 3 connects iirc one's for FM others for ground and extra one is for navi.
    No need to replace FM aerial so just plug that back into new aerial..
    Plug new navi aerial in and feed it down drivers side headlining down in to pillar then into footwell.
    Now you will see a big black connector block in right side kick panel you can add aerial to that or do what i did and tape other end of lead together then feed it up to rear of head unit job done
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. tv aerial
    By VEC-MAN in forum General Chat
    Last Post: 28th February 2010, 12:41
irmscher vectra aerial
vectra c sat nav aerial
