Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Corsa VXR Side Repeater Surround Conversion
    Leicester
    Default Corsa VXR Side Repeater Surround Conversion
    I decided to give this modification a go to see how it looks.
    Firstly, this is what you need. 2 x Corsa VXR side repeater surrounds. Part Number 13250944 and should cost you no more than about £15 each.
    Time Taken - Approx 20 minutes when taking your time.
    Moving now to the car, here is what we start with.
    Get a simple kitchen knive for this job. Push against the right hand side of the indicator and it will pop out. DO NOT try to use the knife to push between the indicator and bodywork, this is where you WILL scratch the paint.
    A gentle push to the left releases the light unit.
    Once removed.
    Then remove you badge and clean the surrounding area. I used Meguiars general purpose cleaner.
    As the Insignia has a curve to the front wing, it is best to put a slight curve into the indicator surrounds. This was done by gently heating the panel over the hob, then using a rolling pin, very gently roll it back and forth and you will put a slight curve on the panel.
    Once done, you can them fit to the car. There are two little lugs inside the VXR surrounds which locate on the bottom edge of the Insignia's front wings.
    Simply line up and stick them on. Once on you can then re-connect the side repeaters and clip them into the VXR panel.
    Job Done.
    You will find that they do actually point slightly down. I was a little concerned about this, but it actually follows the swage line of the side of the car.
    I did try them on in a level position but it looked really bad and not in line with the car.
    So I am pleased with the result, just got to decide whether to have the SE badges back on or leave it clean.
    Opinions and comments as always are appreciated.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Not sure on them myself, I have been staring at them for a few mins now, but can't make my mind up - the thing that jumps at me is that they are very close to the edge of the wing and door.
    Possibly need a picture from a bit further away, but I don't think they look too bad mate - the honeycomb goes with the front grill too...
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Me 2, I am not 100% sure ont them. Please can we have a photo of the full side of the car. As I never can always tell unless you see the full car.
    But there have grown on me from first viewing.
    Leicester
    Here you go.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Hmm... yeah, I do like them
    Leicester
    Thanks Dan!
    If they followed the rear line of the door they'd be perfect, but yeah I like them too...
    Oh, and have ordered the fitting kit for the TA...
    Should go well with the switches for heated rear seats and the rear twin audio which I can fit...
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    looks very smart, a nice classy touch
    Leicester
    The question is, do I put the SE badges back on?
  1. Side Repeater Lenses...
    By Leemarksmith in forum Non Vectra C/Signum Album
    Last Post: 21st March 2010, 15:06
  2. Side repeater help??
    By Clugie in forum Styling
    Last Post: 22nd July 2009, 18:45
  3. Side repeater lens
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 15:06
  4. Side Repeater Replacement
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2007, 09:47
  5. N/S/F side repeater inop
    By OllyVXR in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2007, 15:59
vauxhall zafira side indicator trim surrounds
