Results 1 to 2 of 2
Thread: IAT sensor
    Reading
    Default IAT sensor
    Evening all, a quick overview......
    Jumped in the car CDTi 150 SRi estate, yesterday evening, noticed a definate lack of power, and a fair bit of smoke, was poking about this morning and noticed the swirls were in the wrong position, turns out the link rod from the actuator to the swirls had broken, stripped it out , managing to break a lug off the vacuum tank, toddled off to VX in Newbury, picked up the rod and asked about the tank, mechanic said to just junk it and bypass it out of the system, put the car back together and its coming up with fault code P1110, which is IAT sensor (d/c) open/short.
    Does anyone know where the IAT sensor is located, so I can make sure the plug is on, or replace if necessary.
    Many thanks in anticipation
    Mark
    Reading
    Further to a bit of investigation, I'm led to believe that the iat sensor is part of the maf, joy, guess I'll get a new one of those then.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
iat sensor opel vectra
