Thread: HiD Problem
    Regular Member Chris R's Avatar
    Jan 2008
    Leamington Spa
    Default HiD Problem
    I owned a pair HID's which came out of a vaux omega once upon a time and had a problem with the passenger light becoming a bit faulty and had the obvious warning signs of bulb faulty. They then had thier time spent so i bought a new set of 7k HID's and still having the same problem of the passenger light faulty but the drivers side never seems to be a problem.. Does anyone know why this happens and how this can be stopped as it can become very frustratin drivin down a dark road with just one headlight
    Many Thanks
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    flickering?>
    Jan 2008
    Leamington Spa
    no not flickering, i can drive one way with both headlights, turn the car and lights off then on the return trip home i turn my headlights back on and find that the drivers side headlight does work, but the passenger side doesnt????? baffled lol
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Are you always putting the lights on after the car is running?
    Jan 2008
    Leamington Spa
    yea i tend to drive with lights on all the time, its an army thing been planted into me
    Quote Originally Posted by Chris R View Post
    He meant do you first start the engine, then put on the lights; or do you put on the lights, then start the engine?
    If the latter, then you could be suffering from voltage drop which would explain why the headlight doesn't always come on.
    Jan 2008
    Leamington Spa
    Doh! sorry, yea i start the engine then switch on the lights normally. is there anythin i could do to stop this from happening?
    Jan 2008
    Leamington Spa
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Could well be a low power issue... If the earth or wiring is slightly off the correct voltage/current draw wont be enough for them to be ignited.. check earth connections and headlight connector..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jan 2008
    Leamington Spa
    ive definately checked the headlight connecter, i know bit of a dumb question but where would i be lookin to check the earth connections?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
