Thread: Help with U581 diagnostics....
    Regular Member swirl80's Avatar
    Jun 2009
    Default Help with U581 diagnostics....
    i've just bought the u581 diagnostic kit to trouble shoot the traction control light on my vectra as well as parking sensor issue on the pug. Went for this one as it says will do both cars. However, after the scan, it says there are no trouble codes picked up. Even though on the pug i can see in the alert log an alert about the parking sensors and on the vectra the tc light is on!!!
    any ides what i'm doing wrong? Followed instructions:
    plug in
    switch kit on, wait til tells you to switch ignition on
    switch ignition on
    collects data
    but no codes brought up!!!
    any ideas??
    Full Member Big Sig's Avatar
    Most will only read engine codes. The Tc and parking sensor issues are not engine faults so I doubt it will read them, they are generated by different control modules.
    Regular Member old cruiser's Avatar
    slough
    I've got that code reader also mate and It only reads engine codes as far as I can tell.
    Cheers Pete
    Jun 2009
    ******!!! I thought it'd do the lot. Are there any out there that do parking sensors/tc as well as engine codes??
    Yes but they are very expensive normally
  1. Diagnostics
    By neill in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 10th April 2012, 19:55
  2. Car Diagnostic Code Reader / Scanner OBD2 CAN U581 2009
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
  3. Vectra 1.9cdti (150) and using U581 code reader
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 17:28
  4. U581 Diag Tool
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 21:37
  5. U581 Fault Code Scanner
    By robzc in forum Engine & Drivetrain
    Last Post: 8th December 2007, 14:48
