Results 1 to 3 of 3
Thread: egr valve z19dth .
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    Default egr valve z19dth .
    hello guys have noticed a lot of people using fiat blanking gaskets for egr i've had 3 valves on my 150 in a year was speaking to vauxhall tech today about this they advised not to use these gaskets because of other problems can occur because fiat run different software to vauxhall and when they fit them gaskets they change software to reduce flow but vauxhall wont update there's. was told that when new egr is fitted ecu should have air flow sensor reset because it learns pos for egr feedback threw the air flow reading if its not reset it takes old reading which can afffect egr
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by paul wingnut View Post
    Pardon my French but sounds like a load of **** to me, new EGRs go straight on with nothing else needed. Fiat don't update any software when they fit the gaskets, neither do Alfa.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    the only problem you May have fitting this gasket and some have, you may get eml light on if your software is up to date!, and i would say yours would be, mine isnt and have no probs, buy one from fiat its only £4 ish and fit it your self, saving the old gasket to refit if it dont work.
    http://www.vectra-c.com/forum/showthread.php?t=106837
    pic a thread here. you need square 1
  1. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  2. z19dth
    Last Post: 22nd April 2011, 08:38
  3. Where to buy Z19DTH EGR Valve from?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2009, 20:19
  4. New Z19DTH EGR valve...
    By danBoy in forum Parts for sale
    Last Post: 16th November 2008, 17:00
