Thread: headlights
    norwich
    Default headlights
    Hi, I have a 2006 Signum. Can i put HID bulbs in it or do i have to make any modifications
    cambs
    Quote Originally Posted by ncfcsignum View Post
    put the hids straight in m8
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by mhvcbv View Post
    Slight clarification.... you can put an HID KIT straight in... but you can't just take incandescent lamps out and replace them with HID lamps - the electonics are very different. (As are the voltages involved).
    Regular Member LEEROB695's Avatar
    scunthorpe
    before i ask this question i will put on my asbestos jacket before i get flamed lol
    how do you know what type of lights you have ?
    i mean how do i know if i have this adaptive forward lighting system or bi-xenon or just standard halogen bulbs
    dont be to hard on me lol
    Regular Member yadziyad's Avatar
    London
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by LEEROB695 View Post
    If you have factory fit HID/Xenon lighting you'll also have headlamp washers. When you turn the lights on the seem to immediately pulse bright then go dim and quickly return to bright white as the warm up. You should also notice a bunch of warning stickers about the high voltage lights.
    If you think you have AFL (Adaptive Forward Lighting) try moving the steering from lock to lock one evening with the lights on and see if the light pattern moves too.
    If you don't have headlamp washers and the beam pattern seems to be static, just take the rubber cover off the rear of one of the headlamps and have a look at the lamp itself. If you take a lamp out (avoid touching the glass) look on the metal base - H7 is a normal Halogen incandescent lamp, X7 is a Xenon filled incandescent lamp.
    Should give you a better idea.
    Regular Member fingers66's Avatar
    Carpe Diem
    Quote Originally Posted by Handyandy-UK View Post
    I was just about to tell him all that.
  1. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  2. headlights
    By SimonL in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 12:50
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
