Results 1 to 10 of 22
Thread: 1.9cdti Cam belt change
    lancashire
    Default 1.9cdti Cam belt change
    Hi im looking at buying a 1.9cdti sri 150 with 90,000 on the clock, It has a full history but i dont know if its a vauxhall history or other garage (going down on friday) the dealer didnt know if the cam belt had been done without checking but was just off out with another customer so i said i would check when i went down. If it hasnt been done what is the recommended change milage? Im hoping its just been done.
    Also is there anything thats likely to go wrong at this mileage. Im hoping that all the usual stuff that happens to these has already happened at this mileage as they all seem to be lower mileage cars that have had all the problems. I hope this makes sense to some people
    cheers, martin.
    Full Member Big Sig's Avatar
    If it hasn't been done it needs doing
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    If no one knows,especially you,when the cambelt has been done,get it done anyway,chances are it hasn't been done,never assume its been done i say.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    cambelt change for a 1.9cdti is 100k or 10 years which ever sooner. So at 90k it would not have been done if the previous owner stuck to the normal service schedule. I would suggest having it done as well as the water pump
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Cambelt is recommended at 80/4 years, personally I would change it immediately as its on ite last legs.
    Vauxhall reduced the service interval for the CDTI cambelt a few times and I believe the 80k interval is pushing it a bit.
    Gazza4
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I was only in my dealers last week and they confirmed 100k. Always been 100k/10 years. Where does the 80k 4 years come from? the 120?
    Regular Member djr69uk's Avatar
    Midlands
    got mine done at 80k and i thought that was chancing it. you're out of warranty after 60k so why take the risk and wait til outer wear limit?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Recently had the 80k service and VX recommended that i change that cam belt, as they recommend 90k. I was going to ask for it anyway, belt, rollers, tensioner etc. All in £320 from a VX main dealer. Apparantly the water pump is on the other side????
    Cheers.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by ghostrider View Post
    Cheers.
    Well that a load of tosh from the dealer. The waterpump is run by the cambelt so it is the same side. 100k is VX recommended timing belt change. And even better the price should be £250 (this is my local VX dealer price which should be the same everywhere, lol) plus waterpump and waterpump fitting
    Not sure I would a dealer who says the waterpump is on the other side of car. We are on about the CDTi 150 arnt we?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by merikiito View Post
    Service book and I have heard this a few times on here. Would you let run to 100k/10 years?
    Gazza4
  1. replacing 1.9cdti aux belt
    By stevie16v in forum Engine & Drivetrain
    Last Post: 14th October 2011, 14:55
  2. 72k on 1.9cdti 150...should I get timing belt done?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 15:14
  3. 1.9cdti (150) timing belt change £210 is this ok?
    By kirkyoke in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 22:36
  4. cam belt change 1.9cdti (120)
    By bigsteve in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 17:16
