Thread: Intermittent check engine light and limp mode
    New Member Loaf's Avatar
    Ireland
    Default Intermittent check engine light and limp mode
    I have a 2002 Vectra c 2.0 dti
    About once a day while driving the little car and spanner light comes on and the car won't boost.
    If I pull in and turn the engine off and start it again the problem has disappeared
    The light seems to come on when I am at around 1500rpm and under load (up a hill etc)
    I have tried the thing with the brake and throttle to see what error code I have but the engine light doesn't flash.
    Is this a problem anyone else has had? I really want it fixed.
    Aaron
    Ireland
    bump
    Ireland
    anyone?
    6 Post(s)
    The pedal trick doesn't work on all Vauxhalls. This means you might have to fork out and pay for a diagnostic check.
  1. Lumpy engine then limp mode
    By themarbleman in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 20:17
  2. engine management light "limp" mode
    By welshoneder in forum Engine & Drivetrain
    Last Post: 28th October 2010, 10:31
  3. Engine rebuild and now in limp mode
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 4th August 2010, 01:10
  4. 2.2DTI LIMP MODE + SPANNER + Engine Managment Light
    By s0501291 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:42
  5. Intermittent limp mode on 2.2DTi
    By Celes in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 23:12
vauxhall vectra has intermittent lumb mode and engine light on
