Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Fuel Pump or Reg
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Angry Fuel Pump or Reg
    Well I should of known it was in the post at some point last night driving home Spanner came on the dash loss of power manage to limp in to a layby to see what the problem was.
    I took the keys out of the car then tryed to start it a minute later the revs were fine then once the revs dropped that was it limp mode again I managed to limp home from near the m56 to middlewich going very slow.
    Im just wondering If its the Regulator as when you first start the car it revs fine then a couple of seconds later spanner comes on Idle rough as **** and its in limp home mode?
    Its booked in today for the recall on the Reg so fingers crossed if that does not work I have a spare fuel pump here that I bought 2 years ago just incase however its second hand and still may not work.
    Oh yes one other thing when the idle start sounding rough it sounds as if its missfiring too any help appriciated what a ****
    Apr 2008
    Liverpool
    Just been out to it again when you try and rev the engine it looks like its miss firing would the fuel pump or reg cause this?
    Apr 2008
    Liverpool
    Regulator fitted and no more limp home mode now getting a miss fire thinking its the coil pack!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Gutted mate, fingers crossed its the coil pack. Did they not tell you the code's when they hooked it up to the Tech 2?
    Apr 2008
    Liverpool
    I know mate Its just strange that both the reg and the coilpack both went at the same time but they did not tell me about any codes
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Sean-2.2Direct View Post
    I always thought that was the procedure, plug it in read /reset and codes then carry out the work needed?
    Regular Member doughy's Avatar
    Jan 2010
    Wisbech, Cambridgeshire
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    When i had my recall work done they didnt hook it up to anything, just opened the bonnet and changed the regulator and drove it out.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by doughy View Post
    I thought it was a software update?
    Apr 2008
    Liverpool
    Its bad mate anyone selling a Coil pack.
    Rushy Is there any Performance coil packs just for the sake of buying insted of the standard one
    Jan 2010
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    He replaced a physical part on my motor.
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel Pump
    By seanyis in forum Engine & Drivetrain
    Last Post: 6th April 2009, 10:08
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
