Thread: alternative power feed to 12v sockets
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    Unhappy alternative power feed to 12v sockets
    Hi folks
    One annoying feature I would like to sort out is the fact that the power supply to the 12v auxilary sockets (both front and rear) only exists when the ignition is turned to position 3 (Ignition lights on or engine running). The issue is that I have a parrot wired in to his feed and also use a DVD player for my little daughter in the back and if I need to switch the engine off both devices go off immediately which is a pain especially if the dvd goes off (some screaming and crying etc ).
    Now if I could just turn the key to position 2 to turn the engine off but leave the power on.
    I have had a quick look in the fuse box for a feed but never really digged deep until now.
    Anybody had the same problem and worked out a solution?
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Id run the wires from the fusebox in the boot.. theres some live feeds.. and run them to the inside of the car.
    Oct 2007
    Is there a fuse that is live on position 2 of the ignition key and is off when the key is removed?
    Engine : 2.2 Direct
    nope its constant live.. but then i put in a swith for the dvdplayers.. so its just not always on..
    Oct 2007
    I've already got a live feed in the existing wiring to the 12v aux power sockets that I plug the dvd's into and the parrot is hard wired to but it's only on when the engine is running. I want a feed that is on until I take the keys out of the ignition then it turns off.
    Oct 2007
    little bump...
    Regular Member SRi Oli's Avatar
    Barnsley
    My parrot doesnt go off straight away, it stays on for a short time before i remove the key with a message asking if I want to transfer the call to the handset, not sure how long it stays on for though, I either keep the engine running until I finish the call, or press the button to transfer back to the phone straight away, I'd go out and check for you but its on the dining table at the moment waiting to be fitted into the new car, I've not had time yet.
    It was connected via a SOT lead and the power was taken from the front accessory socket.
    Oct 2007
    Yeah same here with my parrot, I can turn off the engine and transfer the call but I am lazy and would like to carry on a conversation hands free without the engine turning if I need to.
    It's probably the dvd issue in the back that I would like sorted the most. If I have to call in at the garage for fuel or something like that where I have to turn the motor off her DVD goes off. If that's not bad enough when it comes back on it starts from the beginning again!! Both these result in..!!!!!!
    One issue is related to the other if you know what I mean? I just need to find a live that is on when the key is at position 2 as I don't really want the sockets live all the time.
    Oct 2007
    Jan 2012
    Tyrone, N. Ireland
    Trim : Leather
    Engine : Z19DT
    Mileage : 85,000
    Did you find a live that was on in key position 1 (or 2) above as I am trying to do the same.
    All help greatly appreciated.
    My car is a 2008 1.9 CDti 120 Vectra
  1. Lost power from 12v sockets..
    By Steven in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 00:06
  2. Power for tow sockets?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2010, 19:20
  3. parking sensors and power sockets stopped working
    By charliepirate in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2010, 13:37
  4. Power sockets and heater
    By badback in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2009, 15:49
  5. amp power feed
    By smartymarty1971 in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2009, 18:01
live power feed vectra boot
