Results 1 to 3 of 3
Thread: Fault indicator.
    In a house
    Default Fault indicator.
    Right guys, Had reason to remove the airbox on my motor today (56/07 Reg SRi 1.9CDTi 150) after I had put it all back together I noticed that I now have a fault indicator lit up on the dash. (Profile of an engine)
    The only thing I can think of that may have caused this is the fact that I unplugged the connection to the Mass air flow sensor located on top of the airbox.
    Would this have caused the little engine profile indicator to light up on the dash, I'm certain that I did not disturb any other sensors or wiring whilst I was removing / refitting the airbox so this is all I can think of, am I right or could it be something else ?,
    your comments would be much appreciated,
    Regards,
    Saxman.
    Glasgow
    You have turned the ignition on while the multi plug has been disconnected from the MAF. Dont worry it will reset itself within a week or 2.
    In a house
    Quote Originally Posted by byebyeitsagsi View Post
    Cheers bud.
  1. Indicator Fault
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2013, 23:50
  2. Indicator fault
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 16:29
  3. vectra c indicator fault please help
    By SRIDAN in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2010, 22:13
  4. Indicator fault
    By Sp33dy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 03:34
  5. Hi All- NEED HELP WITH a Signum INDICATOR FAULT PLS
    By okanac in forum Introduce yourself.
    Last Post: 22nd June 2009, 21:36
