Thread: How to check oil level on 3.0 Diesel Auto box
    Ripon, North Yorkshire
    Default How to check oil level on 3.0 Diesel Auto box
    Hi
    Cant see a dip stick. I need to check the oil level. Is there a hole to check fluid level and is this done hot or cold?
    Is it under the battery box as I cant see it?
    Should the auto gearbox oil be changed as part of a service. Any ideas about what mileage this is?
    N
    I decided to drain the oil. I got 3.1 litres out. It was brown/black and a fair amount of swarf on the magnetic drain plug. the car has done 92000 miles. Dont think it has been done before from the service history.
    I have not been able to get any information about change intervals or the oil required or the quantity.
    I decided to put 3.6 litres of ATF dextron 2 back in. Have used the car 10 miles and so far so good.
    Come on garage mechanics. There are lots of us 3.0 diesel auto owners in this community that need to benefit from your advice. Haynes dont do a manual. There is no info out there. I would be very grateful to know if I have done anything that is correct. I'm just guessing and worried.
    Any other owners of the same config out there that know about this?
    Please respond
    I have found out from a Halfords list in the store by the Oils that the gearbox is meant to take 7 litres. Presumably when draining some of this stays in the torque converter. Has anyone any information on the amount that should come out?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    What type is the gearbox? AF33 or something else?
    The AF33 and AF40 are both covered in the Haynes manuals and give capacities.
    Not sure what my gearbox is but it is the one on the V6 and not covered in the Haynes manual.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    What year is it? Prefacelift or facelift?
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    you cant change the filter is a complete strip and rebuild of the gearbox to do this i know stupid design but thats the japs for you (gearbox is made by aisin warner so is japanese)
    i didnt have to remove any selector you will however need around 8-10 litres of oil as its a multiple part drain and flush the oil you need is type 4 atf and is quite expensive comma make one and call it asw (must be this oil or wont work properly)
    release the drain plug underneath to drain the fluid probably only 2-3 litres i then replaced it and refilled through the sensor hole on the top as it saved removing anything other than 1 bolt check the level using the dipstick with the engine running in park once level correct leave running for 5 mins take for a quick spin (3 miles ish mixed driving) repeat this process around 3 times.
    reason for this is the box just wont release the oil properly and like i said its kind of a flush fill process.
    HTH
    Celses, It's a 2004 Y30DT
    cerbrious, thanks for the great info. Pls can you tell me where your dipstick is as I cant find one on mine?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If it's a 2004 then you have the AF33 gearbox. The dip stick is on the right side of the engine bay (when you look at it) burried deep down the cable mess so it might be hard to spot. It's green and it's held in place by a bolt, not sure what size though.
  1. How do I check the DPF saturation level?
    By inchy1981 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 22:42
  2. This is why you should check oil level
    By Critch in forum The 'Off Topic' room
    Last Post: 11th October 2012, 12:53
  3. clutch fluid level? how do i check it?
    By renton608 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 19:25
  4. Help how do i check my auto gear box level?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:47
  5. Best Time To Check Oil Level?
    By Avenged in forum Engine & Drivetrain
    Last Post: 25th January 2009, 21:38
vectra c automatic box green dipstick
