i need a cheap code reader 4 a 99 model tigra
i have 2x obd2 readers but niether will work
cheers
cheers
which readers have you got and what is happening when you try and use them ?
chris
jus got obd2 readers cheap onesoff ebay
tried em both n it says linking error
both work fine on my 55 plate veccy n our lasses 57 plate corsa
tried them on a 2000 model astra says linking error
and on a 2001 zafira wi same out come
Ive got one like this mate, your welcome to nip across and try it if you like
http://cgi.ebay.co.uk/VAUXHALL-CAR-F...item3ef3f76bb5
It does say though that its only for petrol cars from 2001 onwards and diesels from 2004 onwards.
that exactly same 1 mate as i got n dont work
Shame, it is just a cheap and chearfull one I got when the EML came on, it was cheaper to buy it than go the the stealers to have the code read, might be worth putting in a call to a stealers to see if they can tell you the protocol the car uses?
http://cgi.ebay.co.uk/USB-OBD2-Diagn...item4839ffe991
has any one used this
Ive got this mate & its a good piece of kit.. Pitty u weren't closer as i would let u have a go..
http://cgi.ebay.co.uk/AUTEL-MAXISCAN...item3a5975fbcb
