Thread: steering rack
    Aug 2009
    bridlington
    Default steering rack
    can the seals be renewed on the end of the steering rack where the gaiter meets the rack or do you have to replace the whole rack mine is leaking on the near side thanks
    Regular Member Craig1985's Avatar
    harwich essex
    i had my vecy b ones done, 80p seals but about £100 labour, i had them all done at the same time. i could only find a main dealer to do them as the garages i asked would only fit a new rack
    Regular Member LADmachining's Avatar
    Hampshire
    Often the seals fail for a reason - worn bushes in the rack causing radial movement in the rack and wearing the seal, or a scored/pitted/worn sealing surface on the rack tearing the seal lips.
    Has the car been run with split steering gaiters for any length of time?
    Aug 2009
    bridlington
    just happened last night no warning
    Aug 2009
    bridlington
    Quote Originally Posted by pjabrid View Post
    vectra c 2005 19cdti
    May 2008
    Tyneside
    Car failed MOT in March with leak from end of steering rack. Told they could not be replaced and cost £300 for replacement rack.
    Aug 2009
    bridlington
    recon sounds good at £110
  1. Steering rack AGAIN !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 11:42
  2. Steering Rack!!
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2012, 23:02
  3. Need a new steering rack :(
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2010, 17:44
  4. Steering Rack
    By rob1964bike in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2010, 14:27
  5. Steering Rack
    By maxd cavy in forum Engine & Drivetrain
    Last Post: 26th June 2009, 09:21
