Thread: Black smoke question
    bournemouth
    Default Black smoke question
    okay i have been having a nightmare of a time with my sig as of lately and i have finally got it running but i still have a load of black smoke from 3k revs and upwards so far i have replaced
    dpf
    dpf sensor
    egr valve
    1 boost pipe
    front flexi pipe
    and have cleaned out the boost sensor and throtle body and all other areas but im still getting the smoke
    would it be the turbo or just needing to re generate the dpf
    any help would be great
    my car is a 1.9cdti 120 sig on a 54 plate
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Normally black smoke is a sign of over-fuelling. Can you hear the turbo?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Have you changed the air filter recently,if not,it may be an idea to change it,it sounds like it could be slightly over fuelling and not getting enough air.
    bournemouth
    its got a new k&n panel filter in it and u can hear the turbo faintly but there is a lot of black smoke
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    I'm out of ideas then
    Did it start smoking like this since putting in the k+n ?
    Is it the dpf regenerating perhaps ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the airflow meter to me.
    Gazza4
    bournemouth
    cheers for the ideas guys im really stumped with it know
    on the verge of giving up with it soon
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just to throw a real curve-ball at this one.
    Have you checked your engine temperature sensor (for the ECU, not the gauges if this is separate).
    Was a very common fault on early Vauxhalls, may be fooling the ECU into thinking the engine is cold, and thus requiring the "Fuel Enrichment" circuit to kick in. (A bit like the old choke mechanisms).
    Other than this, what about the MAF sensor - this is used for fueling control under acceleration.
    At idling and gentle cruising, mixture control returns to the oxy sensors.
    bournemouth
    i dont surpose u would know how to tell if the maf sensor is faulty ????
    and where would the temp sensor be as the sensor in the dpf is surposed to be a temp sensor as that was what the part number came up as not that the people at vaux knew that
    West
    A faulty MAF would normally bring up the spanner light, it does sound to me like it's overfuelling or there's a boost leak somewhere.
    get someone to hold the revs down at about 2.5k & check round all the boost hoses & also the intercooler.
  1. Black smoke
    By Toze2224 in forum Engine & Drivetrain
    Last Post: 11th October 2012, 17:28
  2. air box mod / black smoke
    By Guss in forum Diesel Engine related
    Last Post: 22nd August 2011, 15:25
  3. black smoke
    By harny86 in forum Engine & Drivetrain
    Last Post: 10th February 2010, 20:41
  4. black smoke..
    By rec in forum Engine & Drivetrain
    Last Post: 9th February 2010, 22:17
  5. black smoke
    By scoobyman in forum Engine & Drivetrain
    Last Post: 20th August 2008, 22:46
