Thread: TECH 2 and DPF????
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Thumbs up TECH 2 and DPF????
    hi all i went to the stealers yesterday to get my locking wheel nuts removed from my previus thread while i was there i was speaking to the technician about tech 2 and asked him if i decided to remove my dpf on my 06 sri estate 1.9cdti 16v could you tech 2 it out so the car does not even know its there and wont regen. i explained to him that i can knock the insides out and crimp over the pressure tube to stop the light cumming on and he said that he def thinks the tech 2 can erase the dpf from the car so in theory you could weld in a stright through pipe and just cut back the sensing lines or tie them out of the way so for £60 for tech 2 then you have no more dpf probs and no more smokey regens
    he wasnt 100% sure but the tech 2 guru he called the lad was not in that day
    but in your opinion is it worth it for the dpf and will i see a mpg increase and performnce gains
    also is there a cat on the estates with dpf or not???
    any comments or opinions greatly appreciated thanks
    kings lynn, norfolk
    bump hope someone can shed some advice for me lol
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Yes the estate has cat and DPF. I recently enquired about this and was told that it's hit and miss wether it works. Some accept the deletion, others don't. Only way to see, is to try.
    kings lynn, norfolk
    i see so its worth trying to tech 2 it before i gut my dpf then incase it does not work? where is the cat on the 150 cdti estate and is this easy to gut aswell to give more free flowing and is it easy to remove??????
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    I think it would be better to get the DPF deselected first, then if it's ok, get advice from an exhaust specialist (Powerflow etc) about replacing the DPF and Cat with just straight pipes.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Why do you want to remove the dpf anyway?, it wont make any difference with or without it..
    kings lynn, norfolk
    it must make some difference to performance as the gasses have to be forced through the dpf where as they flow through a cat or silencer and must put alot of back pressure on the turbo too
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i know when the 1.3cdti's were beeing removed for the post office and other large fleets they had to change the engine looms and ecu turbo vac pipes exhurst system and loads a little things ...i know with the vectra you get a choice of two ecu's with or without dpf and if you sps the ecu's differently they reject due to a harware problem ....might be best to drill it out the dpf and leave it .....
    kings lynn, norfolk
    Sorry didn't make sense of the last post but did you say drill the dpf outbut don't change any software with tech2 that means when it regens you get loads of smoke though any more thoughts cheers guys
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
