Results 1 to 10 of 11
Thread: No power at all :( Possible blocked injector?
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default No power at all :( Possible blocked injector?
    I fitted an open tipe air filter with a cold air feed to my 120 cdti veccy.
    The other day i noticed alot of power loss, hardly any power infact, but revved up in neutral just fine.
    Popped bonnet to see the bad boy air filter had come unsecure so i had been using the car with no filter.
    I have tryed replacing the air filter. Resetting the ecu by unplugging battery over night.
    If i take it up the rev range in 3rd, when it eventually reaches around 4000rpm the spanner light says hi and i loose even more power.
    Ive rack'd my brain and this is all i can come up with,,,
    1) The turbos up the creek,
    2) The MAF sensor is muffed
    3) Blocked injector/s from sucking in ****!!!
    Can anyone point me in the correct direction.
    Looks like im having a fun bank holiday monday!
    Regular Member LADmachining's Avatar
    Hampshire
    Injectors will not be affected by unfiltered intake air.
    What fault codes do you have stored? Use the 'pedal trick' to find out the codes, then post them back here.
    These cone air filters are pointless, can cause MAF problems, and offer no performance gain over the standard air box set-up.
    Jul 2009
    Tamworth
    The pedal trick does not work on my car. What possible problems could there be? There is no unusual smoke, the car just sounds a little tappier than normal
    Jul 2009
    Tamworth
    anyone?
    West
    You may want to get the codes read, my thoughts are you AFM is failing & probably caused by the cone filter
    Jul 2009
    Tamworth
    afm is the air flow meter yes?
    Could i have a split turbo hose?
    It goes into limb mode over 3500rpm
    scotland
    It's maybe worth taking your EGR valve off and stripping it down and giving it a good clean, worked on mine when i had the same problem your discribing. Its not hard to do mate and there is a good "how 2" with good pics on stripping and the cleaning process. Hope this helps.
    Regular Member djr69uk's Avatar
    Midlands
    mate i've got a hand held code reader and live in Tamworth... PM me if you want a hand??
    Jul 2009
    Tamworth
    Massive thanks to ben (djr69uk) who came round and had a look at the motor with me. Cleared the error codes and they didn't reappear so they must have been a one off fault. Turned out there was a split in a tiny vacuum pipe linked to the turbo, ben has photos that he will be uploading.
    Brilliant result that it was a small problem. And not hundreds at the stealers. Shame we'd already had it on the ramps and the undertray off when there was no need.
    Pics to follow from djr69uk hopefully!
    Thanks again ben!
    Midlands
    No probs mate. Glad we got it sorted
    Here are some pics of the offending pipe:
    That's a very nice motor mate. Just need to get that DMF sorted now and then she's tip top
  1. blocked cat on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 12th June 2011, 22:50
  2. injector cleaner, fuel up grade to V power
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 22:43
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Wonder if this guy blocked his egr!
    By John LE in forum The 'Off Topic' room
    Last Post: 21st June 2010, 09:09
vectra blocked injectors
blocked injector vectra
