Thread: Oil display and temp
    Hertfordshire
    Default Oil display and temp
    I don't have a manual for the car (2.2 dti SRI)at the moment as I'm waiting for the dealership to get me one and when I turned off the car this evening it showed a spanner with an oil can and 1.0 Ltr which I'm assuming would mean add a litre of oil? am I right? Also It's the first diesel I've owned and was wondering which Oil I should be buying It's done 68'000 miles. Last but not least how quickly should these engines take to get up to temperature as It seems to take a while for the gauge to move?
    Full Member Big Sig's Avatar
    Diesels do take a while to heat up, allow about 10 mins really.
    Put what ever oil in as its already using really, if its a vx service history then its probably 5w30 unless the garage was cutting corners - in which case its anyones guess really.
    Hertfordshire
    Ok cheers, Is it normal for the dash to say that I need oil even though the level is actually spot on? I checked it earlier and it bang on the max mark if not a little black considering it was suppose to be changed 2 weeks ago!
    Oil with a spanner? Thats a service light, not a level light.
    Looks like they haven't reset the service. Have a search on here, i know the answer is about
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The dti's take an age to heat up mate, it's normal
  1. Climate control temp display issue
    By Greebo in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2012, 14:11
  2. Vectra C Radio/Time/Date/Temp Display Dead
    By KBW137 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 23:29
  3. Annoying temp display
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2011, 00:48
  4. F in temp display
    By zafira in forum Diesel Engine related
    Last Post: 28th August 2010, 16:17
  5. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
