Results 1 to 10 of 17
Thread: Primer help
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Default Primer help
    Stupid question I know but I have an irmy front spoiler & im not sure if it has primer on it, as I have never seen anything with primer on it. Its white in colour & when I rub my hand on it, its a bit dusty. Would you guys say it has primer on it?
    Dec 2005
    In the sponge-monkey tent
    I believe they leave the factory with primer. Use a cloth with white spirit or similar to get rid of the dust before painting.
    Regular Member Harry's Avatar
    Uxbridge, London
    sounds like it mate.
    they do indeed leave the factory primed..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Ok cheers guys. Any advice for the crack I have made on it? Its broke a very small part off. Anything that I could fill it up with that I would have around the house as its tiny?
    if it's a break you could try superglue.. if it's a pit or scrape then it'll need a litle filler or stopper..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by Gsi3.2
    What type of filler would be best as im new to all this?
    Thanks in advance
    get yourself down to helfrauds and get some easy sanding car body filler.. you can even buy it ready mixed in a tube..no more than £5...
    sand it back to a fine 600 grit paper and re-prime the area.. you'll be able to get some plastic primer there as well..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Ok cheers for that. Last question, where do I get the colour code for my paint & do I just aks my local vx garage for a can of spray paint?
    the paint code is found on the drivers door pillar, on the black chassis plate..
    it will be the two lower codes, one for paint and one for the body trim..
    VX paint will be dearer than helfrauds but will be a better match IMO..
  1. Hand Primer
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2012, 14:37
  2. Which colour primer
    By lizard in forum Bodywork & Interior
    Last Post: 9th April 2011, 18:23
  3. grey or white primer?
    By barney490 in forum Styling
    Last Post: 15th June 2010, 23:05
  4. vxr insertin primer
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 18:19
  5. Vectra primer
    By andyveccy in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2006, 13:30
