Thread: Fog Light constant check warning
    Chester
    Angry Fog Light constant check warning
    Hi,
    I have an 06 Vectra C Sri, over the last few weeks the CD70 started displaying "check nearside fog" as well as the yellow dash light. This is now coming on almost non stop. The Fog is working fine (as are the other lights) Its ****** annoying to have to keep hitting the cancel button so you can see your sat nav/cd/radio etc, but it pops back up after 10-40 secs.
    Any ideas how i can tell the computer everythings fine? without paying through the nose?
    Mark
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    I have the same problem and all I do is turn the fog lights on and it clears the warning light as its ok. I'll will get around to checking the connection for any corrosion or bad connection etc. Maybe a bit of vaseline on the connection will help?
    Regular Member 2wheelstu's Avatar
    Feb 2012
    Warwickshire
    You need to clean the metal contact area where the base of the bulb sits. The corrosion affects the resistance on the circuit and from those readings the system assumes the bulb is blown.
    Engine : 1.9 CDTi
    As above or just replace the bulb.
    As the nearside fog isn't wired up as standard, I'm puzzled as to why you're getting the warning message.
    edit - unless you're referring to the front ones?
  1. safeguard check warning on dash,why?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2012, 00:41
  2. Dreaded 'Check Safeguard' warning
    By alcutler in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 10:32
  3. intermittent check rear bulb warning
    By parttimer1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 19:33
  4. Warning, Check Your Nuts, ASAP !
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 13:39
  5. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
