Results 1 to 10 of 11
Thread: vectra 2004 sw 1.9 cdti new headunit plug and play (NOT)
    Nov 2007
    holland
    Default vectra 2004 sw 1.9 cdti new headunit plug and play (NOT)
    Hello.I am from the Netherlands and want to ask your help because in the netherlands no one knows the solution..
    I have a cdr2013 headunit with iso plugs.
    I have a new radio with canbus plugs.
    What kind of an adaptor do i need???
    thanx
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Are you fitting the NCDC2013 to a full can vehicle, ? or
    Are you fitting a different Full Can radio in-place of the NCDC2013.?
    If you are fitting NCDC20013 to Full Can vehicle...which I assume yours is, as it has a CDTi engine, then you will need an SOT type lead, often used for telemute functions.
    The one you require will be for an Omega B, Late Vectra-B or Early Vectra-C. It will have the ISO plug that will match the blue one in your photograph, however you will have to take your illumination and ignition logic functions from the car, and not rely upon the canbus system. You will need to make up your own conversion lead, by converting the SOT cable.
    If you are going the other way, say fitting a CD70 in place of a NCDC2013, then you will need the later type SOT lead, with the quadlock connectors fitted.
    Which ever way you are going, you will also need aerial plug adapters, which are easily available from car shops and ebay.
    Nov 2007
    holland
    Sorry that i didnt explain it right. THE 2013 comes out. The new radio is so called custom fitter radio for vauxhall/Opel. The new radio has the canbus connection.But i dont know what ā sot cable ? is. Can you explain?
    Sorry for The crappy english.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Hi mate.. its been done serveral times on www.vectra-c.be theres memberes there that have done it..
    you either need to rewire your current ISO plug to the new Fakra plug, or get a adaptor that will work instead.
    But you will loose your Board Computer and check control as you wont be abel to control that anylonger..
    Regular Member tga's Avatar
    Budapest
    Vehicle : Vectra C GTS
    Engine : Z22SE
    Mileage : 287000 km
    Hi everyone,
    I'm new at the forum, so sorry in advance if I ask something that's been mentioned here earlier.
    Just to be clear; if I'm trying to replace an existing NCDC 2013 (half can bus) navi with a newer, full can bus CD70 in a 2003 year Vectra C, there is no any way to use the board computer and the check control system? Are these going to loose for good?
    To be honest, this ye old NCDC 2013 would be fine for me, but unfortunatelly the Navteq does not support the system with Central Europe, especially Hungary map CD...
    Many thanks!
    Engine : 2.2 Direct
    IT can be done..
    You will need
    CD70
    Facelift CID
    convert ISO to fakra
    RGB wire from radio to screen.
    satnav arieal
    If you have ECC you will need facelift ECC panel
    I think you will need new CIM/steeringwheel if the control is going to work.
    Regular Member phe's Avatar
    Feb 2006
    Guadalajara (Spain)
    Vehicle : Vectra OPC
    Engine : Z28NEH
    Mileage : 120.000km
    in the club vectra c of Spain we have done, my car was the first www.zonaforo.com/vectrac
    New CDx0
    New CID or GID screen >2005
    New ECC controls >2005
    Convert ISO to Fakra
    http://img204.imageshack.us/img204/9...dcacd70ww4.png
    http://img161.imageshack.us/img161/8770/radiosopel.jpg
    New steering whell 2005 or >2006 steering wheel + airbag
    If the CIM is 0x015 id code can be programmed.
    CIM id 0x009 and 0x00F need changue the CIM (0x00F the horn sounds continuously if it are programmed)
    In case of CD70, add RGB cable and satellite Fakra
    Budapest
    Engine : Z22SE
    Mileage : 287000 km
    Huh! ECC, CIM and new aerial? It sounds serious... and expensive as well.
    I have to think about it a bit more. My Plan B was a universal balckbox navi, that able to use the factory made CID. But so far could'nt find a reliable one. Any idea?
    Regular Member Jezzy's Avatar
    S.E
    This thread is like the United Nations General Assembly lol
    swansea
    Around the world in 9 posts.
  1. Hi _ im new: Red Vectra 2004 3.0 Sri CDTI
    By mtqn in forum Introduce yourself.
    Last Post: 22nd June 2012, 16:52
  2. Tuning Box for 1.9 CDTi 120 (plug & play)
    By Draggon in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 1st February 2009, 18:01
  3. Considering a 2004 3.0 V6 cdti Vectra
    By FinestJammy1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2007, 15:58
  4. CDTI SRI V6 Vectra 2004
    By masonic in forum Cars for sale
    Last Post: 13th August 2006, 20:29
