Thread: Noise from front end of Vectra through wheels ?, help please
    Apr 2009
    leeds
    Default Noise from front end of Vectra through wheels ?, help please
    Hi,
    I have a Vectra 1.9 CDTI 120BHP on a 07 plate, car has done roughly 112k and for the past 20k it has been making a awful noise when ever I go for driving via lots of A roads.
    It started the second after I hit a pothole trying to avoid a tractor, I hit it doing about 45 and as soon as i'd cleared the tractor, there was a grinding/thumping sound coming from the front end.
    I stopped and checked the wheels and had a quick look under the front end but no visable damage.
    Now everytime I take it anywhere near any bumpy, hilly type A and B roads, the kind you find in the dales, etc, this noise starts again.
    On motorways it's fine and has no noise.
    The noise only starts when I go down a longish type hill after the driving of A and B roads for a while. This noise carries on getting louder and faster the more speed I pick up, so loud infact, that I can hear it from inside the car with the windows closed and doesn't stop until i reach the flat road and then speed upto about 60mph, at which point the noise is so fast, it feels something is gonna break and then it just goes !!
    Now for the strange bit, the noise carries on down the hill in everygear from 2nd to 6th and even in neutral, doesn't matter if i press the clutch down when in these gears, etc. Only thing that stops the noise is braking, but as soon as i lift off, the noise starts again.
    It has being into Evans Halshaw Horsforth in Leeds and they cannot find anything wrong with it.
    Any ideas of what this noise could be ? and do you think i'd be better off trying another garage for its next service in the next few months and see if they can find it. Evans Halshaw seem to inspect the wheel from behind with a torch and never take the thing off if the brakes look ok. Reckon they'd find something if they did it properly.
    I did speak to one of the tech guys and he said Vectra C's can suffer with gearbox issues, but as the noise goes when I brake and in neutral then I'm guessing its not a gearbox problem.
    Sorry for going on, but the noise is doing my head now on days outs,etc.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    could you have damaged the muck sheild and is it catching on the disk ???
    Midlands Mod Shop - NFFC.
    Apr 2009
    leeds
    Hi,
    I jacked the car up this morning and had both front wheels off, couldn't see anything loose or catching anywhere. I checked over the springs, etc but nothing felt loose or even looked broke, but i've read stuff about the springs breaking inside some kind of housing, but really don't know what I'm looking for tbh.
    Also when i sit stationary on the road or driveway and turn the steering wheel quite fast left to right, etc, it makes a clunking/thumping noise and does it as low speed, turning into car park space etc, is this just the power steering making normal style noises or has something else gone wrong.
    It's a company car, so maybe I shouldn't be bothered too much, but don't fancy something going "snap" when I'm driving down the motorway.
    I'm wondering if to mention it to the Vauxhall dealership again, told them twice already but they never find anything, even though the noises carry on intermittently. Or should I pop into a independant Vauxhall specialist and try and see if they have heard of the fault before ?
    Trim : Get a
    the spring in the cup making the noise is a creaking sound on lock to lock, have you checked your drop link's / top mount's / anti roll bar to see if they are all ok ???
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    coukd be the top mount bearings ...or even a spring broken in the sleeve at the bottom .
    but a very strange problem you have .
    Apr 2009
    leeds
    Hi,
    A quick update on the strange noise from my Vectra, took it too the garage for it service/Mot and and it turns out that it was the passenger side brakes, they had bent slighty after I hit a pothole one day and it took 2 different garages and 20k miles to find but in the end the fault was that catching and grating on the wheel but only when I took the car on a run up through the hills and made the suspension and brakes work like mad, on motorway runs it was fine. The garage replaced the pads and discs and I've no noise since.
    Thanks to all who helped out on listing possible faults before hand.
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    glad you got it sorted
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Loud noise from front wheels! Please help me! :(
    By Kristypie in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2011, 18:34
  3. Noise from front end of Vectra, help please
    By da_melonuk in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2010, 10:54
  4. loud noise from front of vectra sri
    By tractordriver28 in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2009, 23:02
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
vectra feels loose on front end
