Thread: Rear Wheel Alignment
    Regular Member JDX-SRI's Avatar
    Jan 2010
    Scotland
    Default Rear Wheel Alignment
    Hi All,
    I noticed today that there's quite a bad Negative Camber on the rear wheels of my Vec!
    Does anyone know what could cause this as its only 1 year old? - And how much will it cost to fix?
    By negative camber I mean like this viewing from the rear:
    Any advice appreciated!
    Thanks,
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    A little negative camber is right on the Vec, but it shouldn't be too much.
    I had a full four wheel alignment done on my car yesterday, cost me £58 as I needed adjustments on both axles. My local place that has the four wheel aligment machine does the check for free and charges £29 per axle for any adjustments. Well worth getting done if you're not sure it's right. I did mine because I'd lowered the car last week which affects the geometry quite badly.
    Edit: just checked the print out I got given with mine and the recommended angle for the rear camber is -2.12 degrees per wheel with a toe angle of +1.8mm per wheel.
    The front should be -1.03 degrees per wheel camber and 0mm toe.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    i dont know if this is what i need but when im doing 30mph the car dont seem smooth its as if the road is bumpy all the time even at 70 its the same, ive had my shocks and upper control arms done but does the car need to have this done once they have been done? or does this sound like tracking?
    You have an SRI, so it should have a negative camber of about -2'36 +/-15
    If in doubt, get the tyres to the correct pressure and take it to an outlet with Hunters geometry equipment
    Cost you between £50 and £80, well worth it
  1. wheel alignment
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 10:57
  2. 4 wheel alignment done
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2011, 09:44
  3. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  4. 4 wheel alignment for £40....
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 22:40
  5. Wheel alignment
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2007, 21:49
how to adjust vectra c rear camber
vectra c wheel alignment
wheel aalignment adjustment on vectra c
can you rear wheel alignment on the vaxhall insignia cdti
vectra c rear wheel alignment
how do i adjust vectra c rear suspension
can you adjust tracking vectra c estate
vectra c rear wheel tracking
vauxhall vectra rear wheel alignment
vectra c rear wheels alignment
vectra c rear tracking
vectra c rear suspension alignment
vectra c alignment negative camber
back wheel alignment on opel insignia
vectra c rear alignment
vectra c pyöränkulmat
