Results 1 to 10 of 17
Thread: Will not start!! after 100 mile run
    coventry
    confused Will not start!! after 100 mile run
    Has anyone had problems with 2005 2.2i, turns over but will not start, I have check that the fuel is getting to the inlet/ injectors and that the coil pack is sparking.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Does it start on a cold engine?
    coventry
    not started for 3 days now aa not even sure what the problem is! as its not showing any fault codes
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Take its a 2.2 direct could it be the dreaded fuel pump ?
    Irmscher Insignia CDTI 130
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by bigmac View Post
    They tend to start and give trouble when you put your foot down.
    Does it turn over fine, as in no odd noises, and does it turn over at its usual speed? Have you checked compression?
    coventry
    was tickin abit before, turns over a little fast, compression seems ok, just don't understand how you can have fuel and spark and it not ever seem to try and start. has enyone ever had imob stuck on?!!
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ingham465 View Post
    When you say seems ok what does that mean, have done a test? Ticking on a 2.2 is not really a good sign. You are aware of the chain failure's on the 2.2's I take it? I would really want to check the compression properly TBH.
    Wales, UK
    Rushy, are you thinking the problem might be t/chain related ?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by mark_647 View Post
    Just something to rule out mate, he has spark, he has fuel so all we really need is compression and it all timed up properly. Thing is nowadays these engines have multiple sensors so it could be anything, but its dead easy to check compression at home and no need to get it plugged in.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Do you mean it's turning over faster now than it used to? Have you tested the compression?
  1. 233,000 mile Vectra
    By jay w in forum Quick Photo Album
    Last Post: 17th January 2013, 22:39
  2. £38.51 per mile
    By spoons in forum The 'Off Topic' room
    Last Post: 13th July 2012, 07:22
  3. My 1/4 mile results.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 18:13
  4. 40,000 mile service help
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 15:35
  5. GSI 1/4 mile time ...
    By John H in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2006, 10:58
