Results 1 to 10 of 25
Thread: Cdti oil in manifold
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Cdti oil in manifold
    Ok after replacing the inlet manifold on my cdti i have set about trying to locate where the oil was coming from that enters the inlet system and trying to eliminate the restart up of the gunk saga, Im sure our problems are 1' hot dry sooty gases from the EGR enter the manifold and 2' are mixing with an oily/air mix coming in right next door via the throttle body!, pretty obvious realy, so aswell as putting in the fiat semi blanking gasket i set about tracing where the oil was coming from (pretty sure ALL cdti's get this ) i have found that oily resadue is being sucked in to the air system from the oil seperator along this route pointed out!, Now to find a way how to stop this any ideas ??.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    oil catch tank might be needed .....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I did think that but the small pipe pointed out goes into the larger intake one giving a sucking action so wouldn't be sure where to put one, think i would have to intercept that small pipe and do a divert via an oil catcher, daft really cos that,s what the standard oil separator should do!, how about cutting into the pipe and (rough guide only) reconnecting back into the same one again here ish.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    missed the pic!.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Someone installed a catch tank only a week or two ago but I can't find the thread, I think it was at the end of one about the EGR
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Hey wizard do a search on threads started by me and there's one headed 150 flat spot finally sorted .
    Pm me if you need any further
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ill have a look now!, bit annoying really cos they all have an oil separator but it obviously ain't good enough!, I also took of the fat pipe going into the throttle body and found that it was ''SLIGHTLY'' crusty as well as oily!.
    Mar 2007
    Southport
    Here you go
    Mar 2007
    Southport
    What's the latest on yours Shrimpy
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ok shrimpy! had a look at the thread and to be honest i remember reading it the other day!, I was thinking of leaving the pipe that comes from the oil filler area where it is (light blue arrow) as you have, And doing the same with the red arrowed one as you have, i obviously want 1 in and 1 out but cant see where you have done that, So is it possible to use the port arrowed yellow and have red in and yellow out ?, I would take this and join it shown in the last pic. What do you think ?, i believe it would still need the one going to to air filter pipe to give the vacum to the engine breathing system ?
  1. cdti inlet manifold
    By shinyb1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 14:47
  2. 1.9 cdti manifold advice
    By spongebob in forum Engine & Drivetrain
    Last Post: 4th August 2011, 22:01
  3. manifold on a 150 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2011, 19:47
  4. signum cdti 150 manifold
    By deano1 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 21:02
vectra oil separator
oil separator vectra c site:www.vectra-c.com
