Results 1 to 10 of 13
Thread: Z19DT EGR Part help please !!
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Z19DT EGR Part help please !!
    I have a Saab ( I know, I know !!) I used to have a Vectra C until last month.........however I am in desperate need of help if possible
    I stripped of the EGR valve to clean it out and in the process dropped a small clamp that holds to sufaces together (at the bottom end of the pipe) It is roughly 25-30mm in diameter. I went to the local Vx dealer and I cannot purchase the clamp on its own...............can anyone help please
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    You may have to post a pic if possible to show where it fits
    Apr 2006
    Inverclyde
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Hi, i see you haven't solved your problem yet!, first i presume you've lost or misplaced the clamp ?, try dropping the engine under pan cover if you have one it could be there, that's where most things end up!, secondly i think i mentioned the other day and posted pics of the vauxhall set up!, vx don't use this clamp we have a different set up as shown in the pics, you will have to go to a Saab dealer or maybe alfa of fiat but I'm not sure if its only the Saab that has this clamp but vx doesn't.
    Apr 2006
    Inverclyde
    Thanks for the reply
    I was led to believe the vectra has the same engine. When i went into the local Vx dealer, he showed me a diagram of the vectra engine and the clamp was on it but it wasn't listed as a spare. On the bottom pic you posted, the clamp is in yellow at the bottom of the pipe. I've checked the tray and no luck
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The pics are borrowed from a fiat forum and the 120 shown here does NOT have the clamp! but if ANYONE would be kind enough to enlighten us with a pic of the cdti 120 EGR fittings it would help you, and then you could be clear that you need a saab dealer or other wise.
    http://www.vectra-c.com/forum/showthread.php?t=106861
    The two pics have the same fitting but are NOT clamps, the oval fixing does not come off the pipe and is put on before the pipe end is flared.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I was asking about this part for my 3.0 but nobody seemes to have the answer. I have since sourced another one that is in OK shape...Looks identical to the one you posted here.
    If you want to try this one I can post it...all you'd pay is postage as I don't need the clamp.
    Apr 2006
    Inverclyde
    I can only go by what I have seen and been told but i the Z19DT engine is not common to the Vectra and Saab (8v 120bhp) models then I have been mis-informed and stand corrected.
    On this pic, the part I THOUGHT was the bit required is in the position of the arrow.On the diagram I saw in the Vauxhall Dealership, at that location it definitely showed a clamp with a small bolt at the top. One way or another I will get it sorted but I have only had the car 5 weeks and its a steep learning curve
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    oh right its not the EGR clamp your on about then but a clamp further down the pipe ?? NOT in view in this pic ?, if so i cant see why vx cant get one if it is fitted to our engines! i have a 150 but i will look to moz but i think you may have an offer of one from another poster (celes ?).
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    On the 3.0CDTi the clamp holds the EGR valve onto the EGR cooler/heat exchanger. As per PM, I'll try to find the clamp tomorrow. Always glad to help a fellow member
  1. Z19DT EGR Blanking Help....Please
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 28th January 2013, 19:04
  2. Z19DT EGR Blanking Help....
    Last Post: 16th January 2013, 20:30
  3. Z19DT EML Help...
    Last Post: 19th November 2012, 23:10
  4. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  5. Z19DT vacuum.what is this?
    By tox in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 15:50
