Thread: Alternator belt roller id
    salisbury
    Default Alternator belt roller id
    I have had an annoying whooshing noise coming from my belt area for a while and decided this morning to remove the bottom tray and investigate. It turns out that it is a roller as if i spray a bit of wd40 on it while running the noise goes but does come back the stealers are shut for easter and the spares place dont have it listed, only the main one by the air con pump. Its the one that i have put the circle around does anyone have a part number for this or is it connected to something else.
    I also had the belt replaced last week and it looks as if it is wearing on the side, thoughts please many thanks
    1.9cdti 150 signum auto
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Dont know the part number, but sometimes when a roller has gone they can tilt or wobble slightly therefore letting the belt run to one side.
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Hy m8...
    I have the same problem...
    I had changed the pulley of crankshaft because I`w thinking it is the problem...but it was not the pulley...
    so now i will try to change the roller what you say it clinking on your car to see if the sound go out...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    put chalk on it and leave it alone
    Jul 2009
    Bistrita
    did you think it will no more clinking if i put some chalk on it?
    And how I need to put chalk ON it, or inside it?
    I think it can disassemble somehow and inside it`s a pair of bearing....and if bearing has gone .....need a replacement or i`m wrong?
    Can you explain a little detailed how to repair the roller with chalk?
    Thanks.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    i thought you ment the wooshing sound is usally the belt if you put some chalk on it it goes away a vx mechanic told me that
  1. Replace toothed belt and tension roller guide.
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 12:58
  2. Change alternator belt on 1.9 150?
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 29th September 2012, 17:45
  3. New alternator and belt
    By Mark-R in forum Engine & Drivetrain
    Last Post: 14th September 2012, 17:20
  4. Alternator Belt! HELP A.S.A.P
    By rwellfair in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 07:43
  5. dti alternator belt help
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 23:09
