Results 1 to 10 of 11
Thread: Lack of Power
    Regular Member juggernaut's Avatar
    Rugby
    Angry Lack of Power
    He we go again some of you might say!!
    I have a 2004 CDTI 150 just over a week ago it started to loose power slightly so I changed the fuel filter (it was overdue), no difference. Then I looked on the forum and found the various known problems. Took out the boost sensor and cleaned it (not very well as all I had was paraffin) it made a slight difference for about a day. Yesterday took it off again and the EGR and cleaned both (EGR was filthy especially where it's located) with carb cleaner. Took it for a run this morning and it was worse than ever! Flat as a pancake until 2750 rpm when It would take of like a scalded cat. However the more I drove it the worse it got, after 10 miles spanner light came on and car wouldn't rev beyond 3250rpm whilst being driven but I could here the turbo! On the way home just turning into our drive lots of smoke for about 30 seconds then it cleared. Car on drive wouldn't rev beyond 3500rpm but no smoke. Switched it off and on again spanner light was off and car will now rev freely or so it seems. Haven't driven it for fear of making matters worse. When driven the car feels like it's being strangled. Is there something I have missed? It was also loosing power going up hills at 60mph in 5th when normally it would pull like a train!
    salisbury
    does it have a dpf fitted?
    Rugby
    I don't think so, how would I check?
    salisbury
    if you look inside your drivers door there is a label and bottom left it should have, if fitted 0.50. i think that it is only signums and vectra estates that have them but check. if not it should read 1.20 ( my other 1.9 cdti reads this and has no dpf )
    Rugby
    Having looked through the forum again I haven't cleaned the egr valve as thoroughly as I should have (didn't take it apart etc) so I'm going to give that a go in the vain hope it will work
    salisbury
    I been there and done that, it works for a while and then back to how it was. I had to have a new inlet and egr, problem solved, thankfully under warrenty. when you have done it take it down the motorway and drive above 60 and keep the revs high 3 or 4th gear this will blast alot of the krap out of the inlet and also if you have a dpf cause a regen.
    egr clean thread - very good
    http://www.vectra-c.com/forum/showth...gr+valve+clean
    Rugby
    Thanks for link that's what I'm about to try
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Have you checked the swirl valve linkage to see if is connected & moving?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i feel for you , i have the same problem at the minute and im just waiting to get time to get it cleaned out and put the fait gasket in , but my swirl bar is also off
    good luck cleaning it the how 2 looks very helpful
    Rugby
    Problem solved, goes like a train now
    The chap who did that how to needs a medal, thank you very much and thanks for all the other suggestions
    Moral of the story.......give yourself enough time to do the job properly the first time
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:51
  3. lack of power
    Last Post: 6th February 2011, 20:18
  4. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
  5. lack of power
    By astratovectra in forum Engine & Drivetrain
    Last Post: 20th February 2010, 19:56
