Results 1 to 10 of 23
Thread: Insignia VXR Grille Conversion
    Leicester
    Default Insignia VXR Grille Conversion
    OK, here's another one of my 'How 2's'. This time for the fitting of the Insignia VXR to a normal Insignia.
    This is a suprisingly easy job and took less than an hour to do.
    Firstly, the front bumper has to be removed. Time - 5 minutes
    Then remove the complete grill assembly from the back of the bumper. Time - 5 Minutes.
    Here's both the standard and VXR grill side by side.
    As mine is not a VXR, I decided to remove the mat alloy finish grill surround from the VXR grill and re-fit my standard chrome version.
    This is simply clipped into place and needs to be gently removed. Time - 10-15 minutes as it is quite fiddly.
    Here's the mat finish surround removed.
    Here is the VXR grill, complete with the standard chrome grill sourround fitted.
    There is a small modification that needs to be done to the VXR grill frame before you can fit it. If you don't do this, the assembly won't fit flush in the bumper and you will see a gap around the top of the grill.
    So you can see in the picture the raised section that needs to be removed.
    There is one either side to remove.
    Here is how it looks with the raised section removed and the edges finished.
    You will also see below the cut out down the 'hole' a clip, this needs to be removed and transfered to the new grill (If you have Park Assist as it mounts the loom)
    Once this has been done, it can be simply clipped into the bumper, this is the exact reverse of strip down.
    Then the bumper can be mounted on the car.
    I am really pleased with the end result and by keeping the crome surround, it makes the grill more in keeping with the normal Insignia. It also matches up with the chrome badge that is standard.
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    another excellent write up mate , looks awesome
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    glade people are working this stuff out before i get mine loooks great
    St Helens
    Looks very very nice Matt
    Regular Member wise1's Avatar
    Jan 2010
    essex
    Excellent job and a cracking write up - cheers Matt she looks the dogs
    Regular Member david.aka.judas's Avatar
    Suffolk
    very nice but could vx make that badge any bigger??????
    VOTING UKIP IN AVELEY
    14 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by Judas View Post
    lol@Dave yep Dinnerplate springs to mind
    Sunny Dartmoor
    Very nice matt,looks superb........
    Regular Member kpf1grandprix's Avatar
    luton beds
    very nice
    Leicester
    It's exactly the same size as the Opel badge on facelift Vectra C!
  1. Is this a vectra c or insignia grille
    By bigmac in forum Insignia car chat
    Last Post: 28th February 2011, 14:35
  2. Insignia Dual Exhaust Conversion
    By Maverick in forum Insignia car chat
    Last Post: 6th June 2010, 17:49
  3. Irmscher Insignia grille
    By bigmac in forum Parts for sale
    Last Post: 18th April 2010, 21:25
  4. hid xenon conversion kit 4 INSIGNIA
    By jazzy jay in forum Insignia car chat
    Last Post: 11th February 2010, 15:17
how to remove vectra c grill
opel insignia opc grill
Vxr insignia partsinsignia vxr grillevectra c front bumper removalcorsa d front grillvauxhall insignia grillinsignia vxr conversion
