Thread: eml light came on
    Regular Member stephen g's Avatar
    livingston
    Default eml light came on
    i was out last night and my eml light came on not the spanner light the other one , i know you can read the codes with pressing the accelerator and brake together but does anyone have a list of the codes please my car is a 2.0 t edition 100 .
    livingston
    bump iv'e got code 0139 or 0138 it's one of the 2, i done it last night not been out to the car this morning .
    Regular Member logi6260's Avatar
    Wakefield
    P0139 Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
    P0138 O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
    Oli
    livingston
    Quote Originally Posted by logi6260 View Post
    Oli
    thanks mate , my chassis hit of the ground last night in a parking space so it may have broke the sensor i will get it on the ramp today and have a look
    livingston
    as it says sensor 2 there must be more than 1 witch one will it be ?
    Wakefield
    Sorry mate, no idea, my actual mechanical knowledge isnt that hot, I only know how to do, what I've done, from the How 2's on here, if that makes sense.
    I have a code reader and the booklet indicates that the codes are as above, but doesnt indicate what the soltion is, If you google the code, there are some sites that give probable causes and solutions.
    Oli
    livingston
    Oli
    thanks oli
    Jul 2009
    The Rift, Cardiff
    Sensor 1 is on the manifold in the engine bay, Sensor 2 is on the exhaust pipe after the cat. They look like spark plugs. They get very hot and can virtualy weld in possition. They can be swapped over to see if the fault moves, but its usually not the sensors that are faulty, they just measure the oxygen levels in the exhaust gas.
    I've had same problem for a while and pretty much gave up on it but I now think the egr is letting air in.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
