Thread: Help glow plugs
    nottingham
    Default Help glow plugs
    Hi does anyine know how often glow plugs need changing on a 1.9 120 bhp cdti as my car is struggling to start after leaving it overnight. I have no lights come up on the dash telling me there is a problem but it is slowly getting worse and worse. Thanks in advance
    Sep 2009
    newcastle
    Default glow plugs
    there is no timescale for them can go off at anytime change them
    anyway for how much they cost.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do you get the glow plug dash light up when you first try and start it? If not it could be the glow plug relay. These have been known to play up and did so on mine (150)
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    And i would get a garage to change them lol
    Irmscher Insignia CDTI 130
    Motherwell Scotland
    I changed my glow plugs because of spluttering start, but they made no difference. I am now going to look at the Leak Off pipes which can cause poor starting. Another reason and the most expensive is the injector seals(from an earlier thread) The glow plugs, if you decide to do them are a fairly straightforward job if you are confident and have the right tools. IE I invested in extra long nose pliers to remove electrodes, 1/4 drive deep socket (10mm) and a 9" extension bar. I did remove egr and a fitting above the alternator to give me more room to work but you might get away with not removing them. If you take this on, take your time and use some wd40 to get them out, mine came out fairly easily. Dont over tighten when you refit the new ones. Hope this helps.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by st2malo View Post
    Its not normaly or a known problem (leak off pipes) with the cdti, it is with the di/dti, So are injector seals! Its NOT a common thing with the cdti. spluttering or chugging is nearly always the swirl bar fell off or a glow plug problem.
    nottingham
    Merikiito i do get the glow plug light on the dash it only stays on for a couple of seconds so then i try to start it and it stuggles but does start after about 5 ish seconds of struggling.
    Motherwell Scotland
    Wizard, I was going on what someone posted to my query for the poor starting and no one corrected that thread. But thanks I will look at Swirl Valve.
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  3. Glow Plugs
    By RobW in forum Engine & Drivetrain
    Last Post: 18th March 2011, 20:05
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
