Results 1 to 10 of 14
Thread: Boot full of water!
    Chelmsford
    Default Boot full of water!
    Removed the carpet in my boot today (hatchback) and it was soaking wet!
    Anyone know why?! Is this a common problem?
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by DNS View Post
    yes its a common problem, check ariel rubber
    Regular Member Big Sie's Avatar
    Lanark, Scotland
    Quote Originally Posted by CLOMP View Post
    Could you be more specific please? I seem to have the same problem? Thanks.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    basically, check the rubber seal around the aerial located on the roof of the car. simplez.
    PaZ!
    Chelmsford
    Big Sie,
    Did you sort this one out? I've not tried yet as the aerial is expensive and the roof lining looks like a pain in the arse to remove!
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Big Sie,
    Could you not use some silicon sealant round the base of the aerial rather than replace? Maybe black RTV or similar would work better? Only a thought.
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by si_hoss View Post
    This is exactly what I did with mine a while ago; put some masking tape (small pieces ,so as to shape it easier ) around the edge of the aerial base and smeared black sealant over the cracked areas of the base, sealant used was loctite window sealant from halfords, all still seems dry as I've just checked!!
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The most common reason for a wet boot is the quarter glass. There not stuck in like the windscreen but screwed in as a unit with a seal. Strip back all the trim and you should be able to tighten it up.
    slough
    That's worth knowing for future reference,well done mate for pointing that out.
    Cheers Pete
    Worcs/Staffs/Westmids (ish)
    There's a black sealant by Dow Corning, it hardens as rubber and can even be used to permanently reseal a leaking flat roof, so should do a good job on a car aerial.
  1. Boot full of water, footwells, seats wet
    By Ann in forum Bodywork & Interior
    Last Post: 29th December 2012, 23:02
  2. Front fog full of water
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2012, 20:31
  3. Full service and Cambelt plus water pump £451
    By ryantcb in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 11:17
  4. My cars full of water...
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 00:18
  5. Replies: 5
    Last Post: 7th September 2007, 11:39
