Thread: Rain sensing wipers
    Nov 2007
    antrim
    Default Rain sensing wipers
    I have a 2003 2.2 LS.
    Since the day I bought the car in 2007 the rain sensing wipers seem to have
    had a mind of their own. When its only spitting they may work for a bit
    then go onto max. speed when there is no need and stay on this for maybe
    a minute and then perhaps stop altogether for a minute. This may repeat time
    and again. Somtimes then when it rains heavier they dont seem to go as
    frequent as they should.
    Is this normal ? Does everyone else have them working like this ?
    It doesnt seem to matter if i have the sensor set to the left, middle or right.
    The full speed mode when its only spitting has reduced me to not using
    the rain sensing mode at all. I just push the stalk down for a single swipe now
    or put on standard if rain is heavier but it's doing my head in.
    I wonder if perhaps the sensor is faulty and needs replacing ? Obviously I dont want to have the cost of replacing this if this is the way this rain sensor works for everyone and it will make no difference.
    Any advice and other experiences would be most welcome, Cheers
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Sounds like something is wrong..mine work fine
    Mileage : 000
    Daft as it might sound is there any "traffic film" on the windscreen ( more so the sensor area) this might affect the sensors performance. Try cleaning the sensor area so it is as clean as you can get it. Might just work?.
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    On the odd occasion mine misbehave, a flick of the sensitivity control wheel from one extreme to the other and back, seems to reset them.
    Dunstable
    Quote Originally Posted by ed taylor View Post
    As ed says, if the area around the sensor is dirty etc, it can effect how the rain sensors work, failing this it could be a dodgy sensor as this is what tells the wipers what speed to work on judging by how much water is on the screen. Also check the sensor hasn't come loose somehow and is attached properly and is where it should be, and also may be worth checking the plug that plugs into the sensor to make sure it's not loose
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    after all of the above, if u have no luck, u could just disconnect the sensor and use ur wipers just like any other normal car. simplez.
    PaZ!
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Mines ok when its raining hard but if it then starts to drizzle a bit they some times takes ages to sweep,going to disconnect mine when i get 2 mins
    Irmscher Insignia CDTI 130
    Nov 2007
    antrim
    Many thanks for the advice guys. I've tried to ensure windscreen is clear
    and tried movin the sensitivity back and forward but the thing is
    still temperamental. Will have to maybe replace the sensor.
    Thanks to everyone for taking time to reply.
  1. How do I work my Auto rain-sensing wipers?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2011, 11:23
  2. Rain sensing Wipers
    By Signum Dek in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2010, 01:08
  3. Windscreen , top tint and rain sensing for sale.
    By poves in forum Parts for sale
    Last Post: 8th May 2009, 18:44
  4. Rain Sensing Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 08:51
  5. Rain Wipers !!!
    By Asmiffy in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2007, 15:12
https:www.vectra-c.comforumshowthread.php106999-Rain-sensing-wipers
