Thread: got the car jacked up
    Glasgow
    Default got the car jacked up
    ok so got the car jacked up as i changed my oil today and i had a look at the suspension area as i was having the following.
    crunchy wierd noise when stationary or low speeds and turning the steering.
    noise when goin over some bumps the the suspension is raised some and dropped again (hills n things).
    so with the wheel of the ground i turned the wheel left and right and felt something thru the spring like a vibration or something so i think thats the bearing or something?
    and also wobbled the wheel left and right and thier is a wee bit of play.
    what does that mean?
    im looking at ordering the bits so i can get it all done asap.
    any one got any suggestions? or best/cheapest place for the parts?
    thanks lads
    Dunstable
    If you have a pre-face veccy, it's common for the anti roll bar drop links / bushes to need replacing, these can cause the sound you're describing. Someone on here may give you more idea though as I'm not really clued up on the 'mechanic' side of things!
    Glasgow
    yeh ive been reading alot on here, i jsut ordered 2 from ebay for £17.
    just not sure about the side to side, i think its track rod ends, the outer but not sure?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Will be top strut mount bearing mate dealer part iirc
    Irmscher Insignia CDTI 130
    Glasgow
    what about the side to side matey
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Thought there was always a slight play side to side and thought it was up and down you had to worry about my be wrong though
    Mileage : 000
    Wobblng the steering "play" might be wear in the track rod ends. I belive the inner ones ( tie rod ) can show a bit of "play".
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Quote Originally Posted by bigmac View Post
    Yep, I think you're right with that.
    If the vibration is coming through the spring, it's got to be the top mount I would have thought. Unless it is just the spring twisting in the cup ...
    Glasgow
    the other wheel doesnt do it?
  1. Button gets car jacked in brazil
    By gibbon7000 in forum Motorsport / Formula 1 etc. chat
    Last Post: 7th November 2010, 16:24
  2. Replies: 40
    Last Post: 2nd October 2007, 11:29
