Thread: Over filled coolant
    Sep 2009
    Glasgow
    Default Over filled coolant
    Will this cause problems, just had car in for inlet manifold replacement and the garage has overfilled coolant by about an inch or 2, should i drain this, will be doing a 200 mile round trip saturday dont want it to cause problems.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I would drain it, only because the car will possibly throw it out if you don't
    West Yorkshire
    The car will throw it out under pressure.
    Sep 2009
    Glasgow
    take it there is a drain plug bottom left at the front like astra cdti.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Don't you have a syringe or similar?
    Sep 2009
    Glasgow
    will try to get one tommorrow, since the garage just filled the coolant and the garage is less than 10 miles from home do you think do you think it is over because it hasn't fully bled.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It needs a run ( can be done on the driveway) until the thermostat opens and the temperature is normal and stable once this happens the level will drop slightly if there is air in the system, if it stays high WAIT until it cools down and then remove some of the coolant but an inch in the expansion tank isn't all that
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Oh is it definatly too high? The mark on the tank is the "cold" level. It will rise a bit when hot. Check it again when the car is cold
    Sep 2009
    Glasgow
    car was cold when level checked.
  1. Just filled up How Much?!!!
    By the_wave_rider in forum General Motoring Chat
    Last Post: 19th March 2012, 13:17
  2. should have filled up!
    By TimTay in forum General Chat
    Last Post: 27th July 2011, 14:17
  3. Over filled the oil...
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2011, 11:05
  4. Filled my car up today
    By Steevo in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 10:20
  5. Just Filled Up
    Last Post: 10th November 2008, 20:34
overfilling coolant corsa
