Thread: coulour display trip computer
    aldershot
    Default coulour display trip computer
    I'm shure the question has been asked before but trawling through the threads I can't see any reference to it so here goes :-
    I have aquired a CD70 and display both married from another vectra and I belive not tech2'd. I propose to fit to the same age 07 vectra sri will the trip computer work with the new unit and is the loom generic for fitting ?
    West Yorkshire
    Yes and yes.
    But you will need an additional loom between the display and CD70.
    aldershot
    thanks I have a full set of looms supplied with the setup including the arial so that isn't a problem was just worried I would loose all my existing functions.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by chinese taxi View Post
    For the most part, wiring WILL be the same, however if you are going from a TID or MID, then you may need to check that you have two reds and two browns in the display plug. The basic displays have been known to have only one red and one brown.
    Brown on pins 1 and 2
    Reds on pins 3 and 5
    If you only have one of each, then make up a link for each colour as described.
    The functions of the CID will work, if they were already working in the donor vehicle...this includes BC functions.
    Conversely
    If they weren't working before, then it won't work now.
    If they are married to a previous vehicle, then have you got the audio pass number, as you will need this if you wish to change any settings.
    Such as the check control functions (washer fluid level warning or tyre pressure sensor warnings, which may or may not be enabled)
    West Yorkshire
    Pass code is not required to change settings, thankfully
    aldershot
    sorry guys bit confused with the lingo :-
    1 what is a TID and MID ?
    2 What is A CID?(coulour Information Display)??
    finally will I need a pass code or (decoding as I don't have a pass key) to change the setting .Appears to be a bit of confusion in replys.
    thanks
    West Yorkshire
    Cid is the colour display.
    I can confirm 100% from experience that you do not need the code to change the code index or variant confguration settings with tech2
    aldershot
    Thanx
    will update post with results when i've done the change over
  1. Trip Computer on an SRi
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 20:52
  2. trip computer
    By ptrehearn152 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 23:01
  3. Adding trip computer with the upgraded display.
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2008, 22:01
  4. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
  5. trip computer
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 19:22
