Thread: z22se T chain fix needed
    colchester essex
    Default z22se T chain fix needed
    Hi Guys does anyone know of a garage/mechanic in the Colchester Essex area to fix my 2.2 vectra's broken Timing chain. ps i have the kit already. Many thanks
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    If the chain has snapped,i'm sure it will need more than a timing chain kit to fix it,these engines are an interference fit,so if the chain goes,so do your valves,etc.
    colchester essex
    Yes i understand that. Any idea at what i am looking at cost wise if say valves have bent? Thanks
    • ps whats an 'interference fit' ps?
    Regular Member Signum Dek's Avatar
    South Yorkshire
    An Interference Fit, as it was put, Means that if anything goes wrong, the Engine components will Interfere with each other...as in touch...., When correctly timed the Rotating Parts miss each Other, if the chain has gone then the Valves will have stayed stationary (some in the open position) while the Pistons did their damage..
    Dek
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If the valves are bent you might be better just getting another head (second hand) Have you looked on the 2.2 forum? There might be some heads for sale over there if needed plus the odd guy who could do the work.
  1. help needed...how do you compression test a z22se engine
    By Miketwinny in forum Engine & Drivetrain
    Last Post: 4th September 2011, 00:11
  2. z22se cam chain
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 10:06
  3. timing chain on z22se
    By sdnatlst in forum Engine & Drivetrain
    Last Post: 26th February 2010, 18:03
  4. z22se mpg
    Last Post: 13th August 2009, 19:03
