Results 1 to 10 of 11
Thread: vectra c shark fin?????????
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    Default vectra c shark fin?????????
    hello all as above im after a vectra shark fin not a dummy one there is some on ebay but when i message the sellers they cant guarantee they will fit does vauxhall have a range?? or if any one has had a one please let me know (just a small black shark fin like the bmw have)
    and are they easy to fit
    cheers
    Mar 2007
    North East
    The vec has an amplifier in the aerial base so it's not a straight forward replacement job. Saw a post on one of the astra sites a while back which had modded an Insignia shark fin.
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Just get a dummy one. Remove the aerial base from your vectra. You will need to peel back the roof lining a bit to access the nut which secures it. Then disconnect the blue plug which should be above your drivers side, rear window. This will allow you to totally free your aerial base. Once freed, reconnect it but this time with the aerial base on the underside of your roof (between roof and roof lining) the long arial can stay connected. Just tape it to the underside of the roof as the roof lining leaves a bit of a cavity between itself and the roof. Be sure to seal your fin properly as water will leak in and through your hole, making any passengers in the rear centre seat, a little bit erm... wet
    Jan 2010
    northumberland
    Quote Originally Posted by beethamwest View Post
    lol cheers fella ill have a look sounds a bit of a chore ill see might just leave it and get one of them bee sting ones lol
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    my plan was use the wires from the current aerial..
    An get the stuff from something like this: http://cgi.ebay.co.uk/BLACK-SHARK-FI...item2ea965751c (just the electrics)
    And put it on this: http://cgi.ebay.co.uk/GENUINE-VAUXHA...item2eac27513e
    The insignia one is ONLY for Satnav.. radio it either in rear windscreen or on the roof via a normal antenna.. NOT a sharkfin..
    Mar 2007
    North East
    That looks like a plan Ken.
    Yep shark fin on the insignia is for satnav only.
    Seen a few posts on other places where Insignia owners have had the rear windscreen replaced because the heated elements at the top don't work.........Do the dealers not know it's for the aerial ???? .....I do wonder sometimes.
    Engine : 2.2 Direct
    Probaly not... they just think theres somthing on the roof... must be for all...
    Hanging Heaton / Batley
    20 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    What about your rear washer jet?
    Mar 2007
    North East
    Ken has an estate so that's not a problem. Some serious mod required to do this on a hatch.
    Engine : 2.2 Direct
    there was one the other day.. that used one of this http://cgi.ebay.co.uk/LARGE-SHARK-FI...item414e4f1bf9
    and then drilled it up from behind to put in the washer to.. (cant find the thread).
    but if you have satnav, you have to find the "bigger" arials to have room for the satnav things..
  1. Insignia shark fin on Vectra
    By sulten in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2011, 21:20
  2. Shark fin
    By Stoxie in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 21:47
  3. put shark fin ariel on vectra. and it works
    By wals1h in forum Styling
    Last Post: 5th March 2010, 11:45
  4. Shark fin
    By sri_joe in forum Styling
    Last Post: 6th July 2009, 22:54
  5. shark fin
    By kevyn_s in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2007, 21:44
vectra c shark fin aerial
vectra c shark fin with washer
