Results 1 to 10 of 15
Thread: Foggy fog lamp
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Foggy fog lamp
    Can any one advise if a misted up fog lamp is fixable under warranty?
    I have tried to burn it of the lense by driving (illegally at times) to see if this would shift it but it does not move!
    The car is only around 7 months old and it looks **** with one clear and one fogged up lense.
    it is a known VX warranty issue mate, but they'll only change it if it doesn't burn off the condensation after 20 mins of being on..a bit poor if you ask me ...
    Jan 2006
    Skynet HQ EMEC#5
    I had this on mine, when I checked, I hadn't quite fitted cover correctly and some water was sat in bottom of cover. Not had this since.
    i had the same problem but they wouldn't fix it
    ended up taking the bottom cover off and all is ok now
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    i had this too on the n/s fog i just drilled a couple of small holes at the back of it so the air could get into it ,its been ok and looks much better
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    My car had this when I first bought it - I asked them to rectify it before I collected it (no idea whether they replaced it or just wiped the lens, suspect the latter!). Couple of weeks afterwards it misted up again but after using the lamps a few times over the first autumn/winter it's never reappeared.
    I've seen plenty of other Vectra Cs with one misted up light however so I guess it's a common problem. If it's only 7 months old I'd asked a Vauxhall dealer to sort it for you
    Regular Member MLC's Avatar
    uk
    I solved my problem by wiping the fog out with a badger and getting a new one! That taught it a lesson it won't forget.
    Dec 2005
    West Lothian
    Default Fog Lamps
    Spoke to my stealer today and they are not interested, not even as a favour to me etc.
    I have now sent a letter to Vauxhall "customer care" department for their views on this. Typical they have the dosh and now do not want to know
    I thank you all for your replies etc and will inform you all of my answer from Vauxhall.
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    I'd be interested in the outcome as i've just walked up to my Vec and noticed the nearside fog misted up
    Luton
    Thumbs down I have joined the `foogy' club too
    Nov 2005 Signum - N/S foglight now fogged up. Quite a bit of water inside .. There seems to be some sort of vent arrangement on the back ??
  1. Foggy Day Picture's.
    By Vaux-Man-G in forum Non Vectra C/Signum Album
    Last Post: 4th January 2009, 11:40
  2. A bit foggy
    By ed taylor in forum The 'Off Topic' room
    Last Post: 15th December 2008, 08:37
  3. Foggy fogs!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2007, 11:54
  4. foggy Foglight
    By TonyR999 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2006, 00:36
  5. Foggy fog lamps again!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2006, 07:53
