Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Passenger footwell filling up with rain water
    Regular Member Cerealuk's Avatar
    May 2007
    Dorset
    Default Passenger footwell filling up with rain water
    Its tipping it down outside at the moment (good old england) and I've just gone to jump in my car only to find I have an in-car pond in the passenger footwell, its also wet behind the dash if you reach under... is this likely the front window seals gone ? Any idea of cost to fix ?
    cheers
    Regular Member Teefin's Avatar
    SW Scotland
    check the drain hole under the windscreen baffle.
    Lift bonnet and remove the rubber seal at the top along the back of the engine bay. The will probable be a lot of water in here as the drain hole blocks. use a long screwdriver or similar and find the outlet and clear the blockage.
    This is a common fault and more likely than the window seal.
    Hope this helps
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    May 2007
    Dorset
    Thanks guys, just braved the rain to try my luck .. the scuttle cover thingy wont come off properly as its attached to the windscreen, it will however peel back.. problem i have is I can see the pool of collected water but I cant see the drainage hole.. dont suppose anyone has a photo ? I found one on this forum for the driver side but it wasnt clear enough for a rookie like me
    cheers!
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Get your fingers in there honestly just peel scuttle up and get your finger in there and feel about you will soon find the hole then wiggle
    Irmscher Insignia CDTI 130
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    the scuttle is attached to the windscreen as you say, you just pull it from the front and ease you hand in there and get a plastic cup and start scooping out the water. Once you have got the water out, unblock the hole , take your pollen filter out and dry out the area behind it, we must hope is has not killed your heater matrix. So dry it as best you can a replace the pollen filter
    May 2007
    Dorset
    wahooooo found it
    cheers guys!
    Aug 2010
    Swindon
    Hi I've just brought vectra 05 1.9 cdti Sri 2 weeks ago and my front passenger and rear passenger footwells are filled up with water , I have managed to get carpet up in front footwell but the rear is still damp , do you think my pollen filter was blocked at some point as clear now and never noticed water in footwells when brought car , I have dried out carpets but become wet again next day do u think it's water in car moving about have leak front the front somewhere as foam under carpet in front footwell is soaking and fan motor setting 1 does not work ....I have sat in car when it's been raining hard but can't see where water is coming from , I don't know if I have a leak or it's water from a blocked gutter before I brought the car please help ????
    May 2008
    Derbyshire (south)
    Quote Originally Posted by Lee33 View Post
    Follow the advice above mate & you'll clear it up. Pollen filter may need swapping for a new one by the sounds of it though.
    Aug 2010
    Swindon
    Thanks for getting back to me but I've had new pollen filter put in and can't see any water behind it round fan , do u think I may need new pollen filter housing ( White box ) but can't feel any water round inside there either my obsession to sort this leak is doing my partners head in and not looking forward to winter weather if cant find it before then .....
  1. water in passenger footwell
    By brynsueg in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:25
  2. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  3. water in passenger footwell (help)
    By scottwales in forum General Motoring Chat
    Last Post: 5th July 2012, 07:26
  4. Water in (rear) passenger footwell
    By shoeless79 in forum Bodywork & Interior
    Last Post: 19th March 2010, 00:57
  5. water in passenger footwell
    By Task in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2009, 16:09
vauxhall vectra drain holes
vectra c wet passenger footwell
vauxhall vectra passenger footwell filling up with water
vauxhall signum water in passenger footwell
vectra c carpets wet
vectra footwell passenger water
vauxhall signum water in footwell
vauxhall signum car mats
vauxhall vectra c estate water in rear footwell
signum water inside
vectra water inside the car
vectra water in passenger footwell
my Vauxhall Vectra 08 plate fills up with water when it rains
vauxhall tigra drain holes
2005 vectra c water leaking on passenger side
water coming in on my vauxhall vectra to front passenger side any ideas
remove water vectra footwell
vauxhall signum ns footwell full of water
vauxhall vectra water leak passenger footwell
how to remove gutter trim vectra c
how to get carpet up in vectra
water in footwell vectra
vauxhall vectra water in passenger footwell
vauxhall vectra 1.9 cdti sri water passenger footwell
Vauxhall Vectra 07 Front passengers foot well filling up with water
