Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: CD70 Sat Nav question.
    In a house
    Default CD70 Sat Nav question.
    Hi guys, got a question regarding the installation of the CD70 sat nav unit and screen.
    I have a 07 SRi estate and would like to fit the above, question is, if I did manage to get a hold of the equipment, once fitted would I be able to view all of the none satellite related information (Temp,etc,etc) on the screen that I would have been able to had the unit been factory fitted.
    Also what exactly would I need to fit the unit as it would have been originally. (Leads, etc)
    Regards,
    Saxman.
    West Yorkshire
    I am pretty sure you will be able to, yes.
    I have the CD70 and the board computer on it is more comprehensive than the other displays.
    You will need a fakra aerial:
    http://cgi.ebay.co.uk/SAT-NAV-GPS-AN...ht_2826wt_1166
    And an RGB cable (about £50 from vauxhall), this goes between the headunit and screen. You may or may not have this with what's being sold.
    Leicester
    If you get the colour screen, CD70 unit, the lead as described above, and a cheap GSP arial off ebay, againm as described above, you should be able to get it all in and the full Sat Nav working correctly.
    It does need to be configured with Tech 2. It has been done on Astra H many times. However, there is a stumbling block, the colour screen and CD70 head unit needs to be 'divorced' from the car it is coming out of, this means that the security code has to be zeroed from the donar car.
    If not it just ends up being an expensive peice of plastic.
    West Yorkshire
    Maverick, the divorcing is not necessary if the screen and headunit are obtained as a pair. Also, you usually avoid the need for any tech2 this way.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    mine came alive once the cd70 was fitted.. other than the trip computer etc, i had aircon and blower controls that i did not have before.. its worthwhile upgrade in my book
    i took out a cd30 and put in the cd70 without tech 2 as the screen and headunit were a pair, job done in under half an hour..
    VIP-Member MCD's Avatar
    NE Manchester
    27 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    When i did mine on my old vec, what i found is that with the after market ariel it wasnt as accurate, it would tell you the junction turning a 100yards after youd passed it etc.
    I later fitted a genuine ariel, which was really easy! The hardest part was linking in the rear windscreen jet wash. But once connected, it was far more accurate!
    More interestingly, mine was never divorced from the donor car! Just the matching screen and head unit and connecting lead from the said car was taken... and it all worked perfect, and instantly!
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/XP2'd
    In a house
    Ok guys thanks for the replies, just One more question, would I have to get the headunit and screen from a certain year onward to fit my motor (07 reg SRi estate) or would a headunit and screen from any year be compatible,
    Regards,
    Saxman.
    Leicester
    Quote Originally Posted by stampede View Post
    The CD70 unit is coded to the car, and so is the screen. They may work as a pair, but they are still paired to the donar car.
    Jun 2009
    South Coast
    my cd70 and screen was taken out of a scrapper without tech2...
    West Yorkshire
    Quote Originally Posted by Maverick View Post
    They are not paired to the car, they are paired to each other.
    You can have any code you like in both of them, as long as they have the same code you're fine.
    The fact that Vauxhall have chosen to make the 4-digit security code fr other modules the same as the radio code from the factory has no bearing on anything.
  1. Cd70 question
    By chrisvectra in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 01:36
  2. Another CD70 question
    By dholbon in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2011, 20:47
  3. cd70 question
    By mr bh in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 21:23
  4. cd70 question
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2009, 20:26
  5. CD70 ID3 Tag Question
    By AndySkinner in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2007, 08:24
