Results 1 to 10 of 14
Thread: Please recommend a screenwash...
    Chelmsford
    Default Please recommend a screenwash...
    that DOESN'T smell like rotten eggs or cat pee!
    The recent couple of batches I've used (Tesco I think, I'm tight!) stink when I wash the screen.
    I'd really appreciate being able to clean my window and breathe at the same time!
    Never had any problems using carplan screenwash. Still got a couple of 5 litre tubs left over from when Woolworths were selling it off cheap just prior to closing.
    Regular Member LADmachining's Avatar
    Hampshire
    I have also not had any problems using bog standard 'blue' screenwash available in 5ltr containers.
    You may have to remove and flush the washer bottle, as slime can build up in the bottom of the bottle which will make a new batch of screenwash smell bad very quickly.
    Halfords sell some scented screenwash, but it is quite a bit more expensive than the standard stuff.
    Full Member paul.sessions's Avatar
    leighton buzzard
    i had this too created a how to on removal of the washer bottle to clean it, and now i use the concentrated halfords stuff lemon flavour..smell.. great stuff but quite expensive
    http://www.vectra-c.com/forum/showthread.php?t=87195
    http://www.halfords.com/webapp/wcs/s...egoryId_229902
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by DNS View Post
    I never had this, smells of meths maybe - are you sure someone's not playing a trick on you
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    I used to make up several containers from concentrated - now I use the ready made stuff from Wilkinsons. It's cheap, smells reasonable, and cleans the screen without smearing.
    The Vectra needs a much bigger washer bottle though!
    It really depends on what you want your screenwash to do
    The first thing is to make sure the water bottle isn't contaminated
    Empty and drain using a clear pipe, watching for debris
    Fill to about half with fresh clean water, and repeat
    If possible, refill with heavily salted water and leave overnight, and repeat (empty, refill with fresh water, and repeat)
    When adding screenwash there are different types
    1
    Basic ones offer little or no anti-freezing protection, however these are fine for general driving in the summer when raining
    For this I use ASDA basic at 70p per litre
    2
    Concentrated ones simply have a higher concentration of chemicals to water (the basic ones are at least 95% water)
    Avoid any with advice to take care with paintwork and rubber, these contain methylated spirits (you may as well just buy that then!)
    3
    Glycol / iso-propanol based
    During cold weather conditions these are the ones you want
    Holts is the best, works down to -20'C
    On the label it will clearly state contains contains either glycol or iso-propanol
    I use these between October and April
    A 5 litre bottle is about £4 from ASDA
    You can also add a washing agent as you fill
    When refilling your screenwash, always add at least 100ml of fresh water first
    In extreme cold weather I carry a 1 litre bottle of water in the boot of my car, just in case
    Nextly add the washing agent, I use TESCO washing up liquid, about 20ml
    Next is the screenwash, at least 1 litre
    In summer I then fill to the top with more water, giving roughly 50:50, in winter I continue to fill with screenwash
    Another tip is to use ScreenX
    This costs about £5 per 250ml bottle, applied once every month
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As was already said, your washer bottle sounds like it may need a wash out
    Oh and stop being tight, buy some halfords screen wash, or even better get some from VX
    Regular Member ant6566's Avatar
    gwent
    i use undiluted screenwash in the winter.diluted washing up liquid in the bottle in the summer(scrooge)
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Default Alternative to the tiger
    ANone know what glue/silicone i should use to seal my lights. I used no more nails but obviously this isn't the best type of adhiesive. Anything from halfords, B&Q will do but what type?
  1. 20 litres of screenwash 7.99
    By DAVIDD88 in forum General Chat
    Last Post: 29th October 2012, 18:12
  2. Where to fit screenwash sensor
    By CBak109 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2012, 22:47
  3. The best screenwash?
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 21:17
  4. Screenwash additive?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 17:32
  5. Screenwash Strength
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2010, 17:30
