Results 1 to 3 of 3
Thread: A really bad day
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Default A really bad day
    While I have another 3 weeks to go on the MOT, I had it done early as I need it for work pretty much all of the next 3 weeks. While I didn't necessarily expect it to sail through now it's nearly 7 years old and close to 95K miles, I didin't expect this
    Just about all the exhaust hangers have corroded through. It's only held up by the back boxes. Failed on that. Front brakes imballanced (tester reckons disks are shot). Both rear springs fractured.
    Exhaust is the worst though - needs a complete new system including the cat due to the corrosion. I've been quoted over £500 just for the cat, let alone the rest of the system.
    Add in new front disks and pad and new rear springs and how much! !
    On top of that, the rear bank rocker cover is leaking oil (gasket gone or cover warped I guess) and it's due a service. Cam belt probably due next service if not this (last done around 70K).
    Looking at its likely value I'm really wondering if it's worth repairing . It may well be a matter of seeing how much discount I can get off something else as a p/x in its current state with faults declared. Can't see much demand for a knackered 3.2 Auto though .
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    trouble is next car might need the same. take the pads out and clean the runners and carrier might sort your imbalance
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    That's not good
    I think I would look to do a swifty part ex if it was me. Your not going to get any change out of £1000 could be more
    Time to
    Jon
