Results 1 to 3 of 3
Thread: cut out problem
    milton keynes
    Default cut out problem
    basically got a vec 2.2 direct petrol at work took it for a test drive and it decided to cut out tried to start it again but it just kept turning over, but you leave it a couple of minutes its starts so leave it running after about 30 seconds it cut out, so stuck it on diagnostics and * UNRECOGNISED FAULT *
    so has anybody else had this trouble or possibley an idea of what it is
    THANKS
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    2.2 direct?? dont they have fuel pump problems
    salisbury
    dont know if it is the same but had had a similar prob with an astra 1.7tdi van which cut out even while driving, engine light came on. stopped for a while then would work for various times and distance. rac where called and usual diagnostic, shrugged shoulders and blank look. fault code read fuel pump, injectors etc. thurned out to be the ignition module which is attached to the engine block, changed with a recon unit from bberemain prob sorted.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
