Results 1 to 3 of 3
Thread: Bulb Failures & Front Washers Not Working
    Regular Member DanR's Avatar
    Hampshire
    Vehicle : Insignia 2.0 CDTI Ecoflex
    Trim : Elite Nav
    Engine : A20DTH
    Default Bulb Failures & Front Washers Not Working
    Hi Guys,
    Further to issues with my clocks not retaining settings I decided to check all of the fuses on my Veccy. All were okay except F13 however when I restarted the car a few hours later I had an indicator & foglight bulb failure. Also my front windscreen washers no longer work, the wipers don't move and no water, but the rear works fine.
    I replaced fuse F13 (which incidentally Haynes states is for central control unit, 7.5A) with a 30A fuse - direct swap for the size that was in there, but still no front washers!
    Does anyone have any ideas?
    Also, as an aside I'm sure I have headlight washers too (relevant fuse & relay, invoice for repairs following recall in the service history) but these have never worked - I'm going to bring this up with the dealer when they look at the clocks issue (also going to get the bluetooth module looked at) but I don't have the nozzles in the bumper - just what appears to be a blanking plate.
    Many Thanks
    Dan
    Mar 2007
    North East
    The headlight washers are pop up, so will pop out when they need too. You can carefully pull the cover up, the spring is rather strong and you need to take car not to snap the cover, it just clips on but you can break the clips if you are not careful.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Front washers could be a blocked filter. Take out the screws on the nearside wheel arch and squeeze your hand in there and pull out the pump. clean the filter and replace by pushed solidly back it should work, if you are still getting the pump noise.
  1. Model Year 2007 onwards - Front spring failures?
    By I cdti in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2012, 21:28
  2. window washers not working and
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2011, 23:48
  3. Washers not working
    By Padster72 in forum Bodywork & Interior
    Last Post: 14th June 2010, 20:57
  4. Washers not working :(
    By Diet1985 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2009, 18:10
  5. washers are working weheyeeee
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2006, 21:00
