Thread: Headlamp adjustment message after lowering
    Regular Member Harro's Avatar
    Jan 2008
    York
    Default Headlamp adjustment message after lowering
    Had my Vec lowered today (Eibachs & B4's), now got the headlamp range adjustment warning light showing on the dash. I know there is a sensor for it on one of the suspension arms. Does this need to be adjusted or is it duff?
    Any help appreciated.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes will need ajusting.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by Harro View Post
    I'm guessing that during the shock/spring change, the adjuster arm for the levelling on the n/s/f or n/s/r has been bent or broken.
    Check all the bits associated with the levelling and I'll put money on it that, unless its snapped right off, you won't need a new levelling assembly.
    Jan 2008
    York
    Well had a play around today, this is what I've found:
    -Jacking up the car makes the warning light go out.
    -After disconnecting the arms on the sensors and moving them around, I've worked out it's the rear sensor bringing the warning light on.
    -After measuring the ride height before and after it has lowered 25mm. Which is just like having 3 people in the back.
    -The headlight beams don't adjust when the lights are turned on. They used to move up and down.
    Will have to give the garage who fitted the stuff a ring and see what they say. Although at the moment might be dazzling other drivers if the lights aren't adjusting properly
    Jan 2008
    York
    Well after searching the forum a bit more last night, found a thread with the same problem. And after bending the bracket holding the rear sensor back into shape the warning light has gone out.
    Disconnected the sensor arm as well to check the lights go up and down when the sensor is moved, and they do.
    Super relieved now, can enjoy the look and ride of the shocks and springs.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    They usually need re calibrating via tech 2 when theyve been messed about with..
    Jan 2008
    York
    Yeah, might ring the local dealer and see what they say. How much do you reckon they would they charge for this?
  1. RHD to LHD headlamp adjustment
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2010, 09:55
  2. Headlamp beam adjustment for europe
    By goonturbo in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 20:49
  3. Automatic headlamp range adjustment fault!
    By djhallam in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2008, 09:10
  4. Lowering springs & camber adjustment
    By DTGB in forum Handling & Braking
    Last Post: 29th September 2008, 21:06
  5. AFL Headlamp adjustment?
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 01:36
How can I adjust my headlihht on my vauxhall vectra if the adjuster is broken
