Thread: Discovered RUST on one of my arches :-( Car is 55 plate
    Redcar
    Default Discovered RUST on one of my arches :-( Car is 55 plate
    Discovered rust on one of my arches today when cleaning car :-( Didnt think it would start this soon as car is 55 plate vectra. Is there a corrision warrenty or is it just plain simple 3 year warrenty. If there is warrenty how do you go about chasing it up and whats the terms. If not how can i prevent it spreading. Thanks in advance
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Think you may find its an anti perforation warrenty. it lasts for 12 years but the car needs to have had a body inspection. But as it's anti perforation there would need to be a rusty hole first
    Mine is bubbling in the rear arches too (not rust just the paint flaking)
    I'm going to have to get mine painted
    Blantyre
    Anti-Perforation Warranty
    Vauxhall guarantees new vehicles against perforation by corrosion of the bodywork and underbody, where it occurs as a result of defective materials or workmanship. The warranty applies for six years from the date of first registration except:
    VX220 which has a 10 year anti-perforation warranty on the chassis.
    Vauxhall offers an annual corrosion protection service which should be carried out regularly to maintain the validity of the warranty.
    For full details of Vauxhall warranties including terms, conditions and exclusions, please refer to the Service Booklet with your Vauxhall.
    WGAF#5
    as above and to clarify the corrosion has to be from the inside out - not the outside in --- so if its had a chip in the paint that has not been rectified and the corrosion is from that - it wont be covered
    and as such will only cover the main chassis and not doors and boots and bonnets as these could have been replaced
    Redcar
    Thanks guys for your quick replies :-) Is there any method to prevent further rust like something to coat it with? Its just starting really so not to ovious.
    WGAF#5
    you need to abrade and remove the rust to prevent it spreading - then clean and repaint the area - if you feel confident -have a go yourself = if not a bodyshop should be able to do the job for a "reasonable" cost
    Redcar
    Its all round rim of arch so will it not be covered under warrenty
    WGAF#5
    probably not -as could have been caused by a stone chip - best bet would be to take it in and let them inspect it and tell you what they think as they would be footing the bill - so to speak
    Redcar
    It just on the lip around the quarter, it seems the paint has worn off. If i gently sanded it and put hammerite or something on it would that cure it or stop it from getting worse
    WGAF#5
    gentle sand with very fine grade wet dry then touch up pen and lacquer
  1. Discovered Dash Berlin tonight
    By MURDO in forum General Chat
    Last Post: 2nd April 2012, 22:46
  2. I think I've discovered the problem with Vauxhall's business model...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2011, 00:17
  3. I have discovered Meguiars!!!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 22nd May 2008, 15:32
  4. Arches
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2007, 11:53
  5. Just Discovered last night
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2006, 15:01
