Thread: brakes help
    Oct 2007
    nottingham
    Default brakes help
    hi guys
    have just got rear brake and disc kit from vauxhall,the rear pads are a different design to the ones fitted,so phoned vauxhall dealer where they came from and they have said these are a replacement pad design.
    so whats the difference the ones fitted have a spring on the rear of the pad that slots onto the brake piston.
    new ones have a spring at the top of the pad which does not fit onto brake piston.
    so will these fit as vauxhall have said they will and that they replace the old design,not so sure myself,but does anybody know.
    thanks guys tommy
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep the design was changed mate, they should fit fine
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    It would be good to post some pics of the old & new design showing the differences
    Oct 2007
    nottingham
    Default thanks
    hi john thanks for your quick reply,puts my mind at rest
    tommy
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's been posted a few times, this will be what you have
    http://www.vectra-c.com/forum/showpo...35&postcount=1
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Isn't that the other way around to the OP's??
    I just replaced mine and both had the spring at the edge rather than the back.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Was just an example to say that both would fit
    May 2008
    Tyneside
    Here's another thread on the subject http://www.vectra-c.com/forum/showthread.php?t=67661
    WGAF#5
    the spring is to assist in the removal of brake squeal resonance at low speeds
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
